Home » Audio » Speaker » A power supply/ amp designer has offered to design a DIY amp to drive 0.75 ohm parallel arrays,,,,
Re: A power supply/ amp designer has offered to design a DIY amp to drive 0.75 ohm parallel arrays,, [message #24382 is a reply to message #24362] Fri, 16 May 2008 19:34 Go to previous message
Anonymous
I like low impedance arrays.
I drive my tweeters with an off the shelf power amplifier in
bridged mode at 0.8 ohms and the mids are 2 ohms. Four bridged
amplifiers.
If the amplifier is not in bridged mode, I can do 0.4 ohms/ch,
and 1 ohm/ch.
If I wanted to boost performance more, I would be using simple
'power distribution' amplifier methodology.
No special amplifiers needed, just get some amplifiers a notch about
entry level.
If you need more info because *you will attempt this*, then send me
email.
Previous Topic: Hey Guys, Where Do We Want to Take this Forum?
Next Topic: BR48 for midrange?
Current Time: Mon Nov 30 10:54:46 CST 2026
