Home » Audio » Speaker » BG Neo10 tests
BG Neo10 tests [message #24273] Thu, 24 April 2008 19:00 Go to next message
Rick Craig is currently offline  Rick Craig
I just ran a few BG Neo10 tests if anyone is interested.
Re: BG Neo10 tests [message #24274 is a reply to message #24273] Thu, 24 April 2008 21:52 Go to previous messageGo to next message
justinc is currently offline  justinc
Rick info on these would be great!
Are these going to be released to the diy market anytime soon?
Re: BG Neo10 tests [message #24276 is a reply to message #24273] Fri, 25 April 2008 07:42 Go to previous messageGo to next message
JPH is currently offline  JPH
I am very much interrested !I presume a lot of people are too. also to know the price tag per unit
Thanks
JP
Re: BG Neo10 tests [message #24278 is a reply to message #24276] Sat, 26 April 2008 11:26 Go to previous messageGo to next message
I don't know what they will cost or if they will be released to the public.
Re: BG Neo10 tests [message #24279 is a reply to message #24274] Sat, 26 April 2008 11:35 Go to previous messageGo to next message
I'm not sure when / if they will become available. My tests are pretty much what I had expected. With drivers like this you can easily predict how they will perform given the amount of surface area. I think the applications for this driver are very limited with the best application being a midrange in a 3-way line array.
The element is way too wide to use it as a tweeter with poor off-axis response in the top octave. Harmonic distortion measured low and the benefit of multiple push-pull magnets is evident there. I haven't bothered to check the sensitivity but I would expect it to be similar to the Neo8.
Re: BG Neo10 tests [message #24280 is a reply to message #24273] Sat, 26 April 2008 12:38 Go to previous messageGo to next message
I believe I've heard about these but I'm not familiar with them. Are they a larger version of the Neo 8? Is the distortion lower than that of the Fountek ribbons, espeically at the lower frequencies, as Zaph found when comparing the Neo 3 PDR to the Fountek Neo CD2?
Re: BG Neo10 tests [message #24281 is a reply to message #24279] Sat, 26 April 2008 16:07 Go to previous messageGo to next message
do you have any FR and distortion graphs? BG claims these can play cleanly down to 150hz. Im really interested to see how low these can actually go.
What are your thoughts on using these in an array mtm style with some fountek tweeters and a seperate array using the new lambda td12x to cover up to about 150-200hz
Re: BG Neo10 tests [message #24283 is a reply to message #24281] Sun, 27 April 2008 00:49 Go to previous messageGo to next message
I've only tested them operating as a dipole so next will be a subenclosure. I also ran some dipole harmonic distortion tests.
Re: BG Neo10 tests [message #24284 is a reply to message #24280] Sun, 27 April 2008 00:56 Go to previous messageGo to next message
Yes, larger version of the Neo8. A distortion comparison with the Fountek could be done but this is a midrange so it wouldn't be of much use because they don't cover the same frequency range. BG has a 3-way design where they place a Neo3 in front of the Neo10.
Re: BG Neo10 tests [message #24286 is a reply to message #24274] Mon, 28 April 2008 12:40 Go to previous messageGo to previous message
Chris Brunhaver is currently offline  Chris Brunhaver
Hi guys,
My name is Chris Brunhaver and I head up OEM sales here at BG. While we are committed to the DIY market and have partnered with Parts Express, GR Research, Meniscus Audio etc. to better serve this customer base, unfortunately, we have no plans to release the NEO10 to the DIY market at this time.
We have sent some units to selected OEM customers using them in finished products and I assume Rick got one from one of them.
Feel free to give me a call or email with any questions.
Thanks,
Chris Brunhaver
Project Manager / OEM Sales
BG Radia Corp.
(775) 884-1900 x108
chris.brunhaver@bgcorp.com
Previous Topic: LSAF just days away!
Next Topic: Array kits
Current Time: Fri Nov 13 05:38:49 CST 2026
