Home » Audio » Speaker » Controversy on tweeter's positioning
Re: Controversy on tweeter's positioning [message #24277 is a reply to message #24275] Fri, 25 April 2008 13:05 Go to previous messageGo to previous message
Rick Craig is currently offline  Rick Craig
With the Behringer you can adjust the delay for either cabinet position. The location of the side walls will influence the amplitude of the later arrivals so that could be a factor in which positioning you prefer.
The lobe will always be present with a passive crossover and it may or may not favor positioning the tweeters on the inside. Some have stated that a lower crossover point will eliminate the lobe but that's not true and can be easily proven with a few measurements. The only way to eliminate it with a passive crossover is to make the layout symmetrical with tweeters in the center flanked by a line of woofers on each side.
Previous Topic: So I went ahead and built them. . .
Next Topic: Hey Guys, Where Do We Want to Take this Forum?
Current Time: Mon Nov 16 08:00:00 CST 2026
