Home » Audio » Speaker » ? ART Array VS Zaph's BAMTM
? ART Array VS Zaph's BAMTM [message #24217] Sun, 16 March 2008 13:29 Go to next message
Dan is currently offline  Dan
Hi,
I've posted here before asking about arrays.
I've got a couple more questions : )
How well do you think a design like Zaph's BAMTM would translate to ART Array configuration?
I know it would only be efficient as the tweeter but ~91dB is OK with me.
The Baffle would be 9" x 95", woofers on the center line with 11" C-T-C and tweeter 1 3/8" off center per John's design.
I think the woofer line will need some attenuation to work with my ~12' listening distance.
I had originally thought going 2.5 way, but now I'm really wondering if John's simple & elegant x-over is really the way to go.
Would it be as simple as bumping up the BSC inductor to match things up?
http://i111.photobucket.com/albums/n139/its-loud-dude/DA175/DA175Xovr.jpg
Re: ? ART Array VS Zaph's BAMTM [message #24218 is a reply to message #24217] Sun, 16 March 2008 18:50 Go to previous messageGo to next message
Marlboro
The tweeters in the drawing are way too far apart. Comb filter distortion would be awful.
Re: ? ART Array VS Zaph's BAMTM [message #24219 is a reply to message #24218] Sun, 16 March 2008 19:47 Go to previous messageGo to next message
Those would be ports
There is just one tweeter, I may move it to the middle.
Re: ? ART Array VS Zaph's BAMTM [message #24220 is a reply to message #24219] Sun, 16 March 2008 23:08 Go to previous messageGo to next message
Marlboro
What frequency is the cross to the tweeter?
Re: ? ART Array VS Zaph's BAMTM [message #24221 is a reply to message #24220] Mon, 17 March 2008 01:14 Go to previous messageGo to next message
It's LR4 @ 1450Hz. I'd use the same conponemts on the tweeter as - R6 the padding resistor
Re: ? ART Array VS Zaph's BAMTM [message #24222 is a reply to message #24219] Thu, 20 March 2008 23:23 Go to previous message
Dave is currently offline  Dave
I would put the tweeter at ear level for your primary listening position. I tried to compromise with a 104 dB horn tweeter between sitting and standing, the tweeter can keep up with the mids only at ear level for less than 15 feet.
So the other day I went out and got 8 feet of tweeter, the world is going to be a much better place.
Previous Topic: JBL 2240H for midbass duty
Next Topic: Eminence/MCM 55-1125
Current Time: Sat Oct 24 23:55:06 CDT 2026
