Home » Audio » Speaker » Smoothing in Frequency response graphs
Re: Smoothing in Frequency response graphs [message #24192 is a reply to message #24190] Wed, 05 March 2008 21:28 Go to previous messageGo to previous message
Keith Larson is currently offline  Keith Larson
Hi Wayne,
If you want to get into the math behind a line source its not realy all that bad. The trick is knowing that you need to sum pressure (volts) and not power (watts). The 'power' of a point source does indeed fall 1/R^2, but the pressure is 1/R. That is, power is propertional to V^2. I learned this back in 1985 when I was in college and built my first line source system. Even though I dont think he really knew what I was up to, it was my DSP professors that helped me figure out the 1/R issue. When I mentioned the 1/R^2 power relationship he quickly picked up on the fact that you don sum power, you sum volts.
The model I have predicts many of these effects quite nicely, but it lacks floor and boundary conditions. This would not be hard to add, but for best results reflectivity and absorption would need to be known. Or, you measure and then make the appropriate corrections.
Hope this helps,
Keith Larson
Previous Topic: KEF Reference 207/2 Stereophile Review
Next Topic: Cheap source for drivers
Current Time: Thu Nov 19 09:10:34 CST 2026
