Home » Audio » Speaker » Building an RS8.
Building a a set of Calipso's [message #24162 is a reply to message #24161] Sat, 09 February 2008 19:36 Go to previous messageGo to previous message
Marlboro
I use a three way system: Per channel: 30 dome tweeters cut to a c-to-c distance of about .86 inch, 17 -3.5 inch 3 mm x-max midranges covering the 165hz to 2400hz frequency range, and and 1 -12 inch poly Prop 15 mm x-max 250 watt DVC woofer covering about 20hz to 165hz. The crossover is an analog Rane Ac-23b electronic crossover, 24 db/octave.
The woofers are powered by their own 350 w/ch amp, the mids by their own 175 w/ch amp, and the tweeters by their own 60w/ch amp. Each amp has its own volume controls, so i can limit the amount of volume control that is required by the Rane unit
Each midrange speaker is inside its own completely separate 4 x 23.5 inch tubular enclosure(1/2 outside air space between them), stuffed with 4 lb/cu ft fiberglas wrapped in polyfill batting.
The woofers are in their own slightly small ported enclosure, but the room acoustics compensate, and with the power available to them put out more bass than I need at any music I listen to, and provide plenty of punch I can feel in my gut if I'm so inclined(as I just felt in David Sanborn's STRAIGHT TO THE HEART album.
Marlboro
Previous Topic: Power Taper
Next Topic: lobing in dome tweeters destroying high's
Current Time: Wed Oct 21 04:26:33 CDT 2026
