Home » Audio » Speaker » so I built these lines with a single tweeter
Re: so I built these lines with a single tweeter [message #24134 is a reply to message #24132] Fri, 25 January 2008 20:35 Go to previous messageGo to previous message
Dave is currently offline  Dave
Do you use any type of gasket for the NSB's?
I think next time I'll make a template for pre-drilling the screw holes that hold the speakers in. The openings in the basket are so big that if you don't get it right on you can drive the basket out of it's seat. Sounds like it's easy, and it is, but the repetitiveness gets to you, or gets to me at least.
Previous Topic: Favorite dome tweeters
Next Topic: Speakerlab K Horn
Current Time: Fri Nov 13 07:57:05 CST 2026
