Home » Audio » Speaker » Open back array
negative going signal [message #24014 is a reply to message #24010] Wed, 07 November 2007 08:52 Go to previous messageGo to previous message
lcholke is currently offline  lcholke
Hi Lito,
Is the tube mounted behind the driver and stuffed with dampening material? Is the tube partly closed on the back end? If the tube that reduces the negative signal is acting as a rear enclosure, then the cone travel may be being limited, reducing the Doppler distortion. Is the bass reduced also.
Thanks
-Linc
Previous Topic: Vintage 15" woofer recommendation for OB midbass array?
Next Topic: The Zigmahornets
Current Time: Wed Oct 21 16:00:32 CDT 2026
