Home » Audio » Speaker » If you ...
Ribbons vs domes [message #23969 is a reply to message #23946] Sat, 22 September 2007 05:44 Go to previous messageGo to previous message
Marlboro
"The use of planars or ribbons is better for the following reasons:
1) better sensitivity
2) lower interference patterns in the vertical plane
3) can be operated at a lower crossover point than the small neo dome tweeters"
1. 30 dome tweeters have a sensitivity of 106 db. That's pretty high. 8 planar Daytons will come in at 105. So that's a wash.
2. Theoretically this is certainly true. Sonically, I'm not entirely sure that its audible. I've not been able to find any research suggesting that its a viable concern. Certainly neither the Pipe Dreams people nor the McIntosh people have been concerned about this enough to switch to ribbons.
3. Operating at a lower crossover point is an important consideration: IF YOU ARE USING 6-7 INCH MID RANGE SPEAKERS. For off axis performance,and for the ability to adequately handle the frequencies between 1200 and 3000, having a lower crossover is very important. However if your mid range units are 3 inchers, then off axis performance is less of an issue(especially in you average living rooms anyhow) and coverage in the upper midrange is already assured.
A three way line array using (per side) 30 c-to-c .9 inch dome tweeters, 17 - 23 three inch cone mid ranges, and one 12 inch woofer is a viable way to get high sensitivity, and quality sound without using ribbon or planar speakers. It all twists on the mid ranges. If you use 6-7 inch mid ranges then you have to use ribbon/planars.
Marlboro
Previous Topic: Replacing Monsoon MM:1000 speakers
Next Topic: Basshorn article in AudioXpress
Current Time: Sun Oct 20 08:46:38 CDT 2024
