Home » Audio » Speaker » Frequeccy response?
Re: Frequeccy response? [message #23911 is a reply to message #23879] Wed, 08 August 2007 11:38 Go to previous message
Danny Richie is currently offline  Danny Richie
Hey Tom,
Don't be discouraged. You can make it work just fine if you wire it like a three way design. Cross the tweeter only to the two center woofers. Give them no baffle step compensation. Then let the six outer woofers cover the lower ranges and fill in that baffle step loss. You can use a low order crossover from the outer woofers to the inner two.
Here is a good example of this implementation.
http://www.rawacoustics.com/item__RA8_Speakers_ARRAY,777.html
This worked out really well and sounded really good.
Good luck,
Danny
Previous Topic: GR Research
Next Topic: ART Array DIY ?'s
Current Time: Thu Nov 12 04:02:09 CST 2026
