Home » Audio » Speaker » Frequeccy response?
Re: Frequeccy response? [message #23887 is a reply to message #23884] Wed, 18 July 2007 19:33 Go to previous messageGo to next message
Rick Craig is currently offline  Rick Craig
With a single driver you should pick a measurement distance close to your listening distance. Set your mic height at the center of the tweeter and center it between the ribbon and the woofer line. If the distance is to great to get good response curves then move in a little closer. Choose a topology that will allow you to vary the ribbon level without affecting the transfer function of the high pass section. It may be that the woofer line will be higher in level, if so, try to manipulate the DCR of the low pass inductors to lower the woofer level. Hope this helps.
Re: Frequeccy response? [message #23911 is a reply to message #23879] Wed, 08 August 2007 11:38 Go to previous message
Danny Richie is currently offline  Danny Richie
Hey Tom,
Don't be discouraged. You can make it work just fine if you wire it like a three way design. Cross the tweeter only to the two center woofers. Give them no baffle step compensation. Then let the six outer woofers cover the lower ranges and fill in that baffle step loss. You can use a low order crossover from the outer woofers to the inner two.
Here is a good example of this implementation.
http://www.rawacoustics.com/item__RA8_Speakers_ARRAY,777.html
This worked out really well and sounded really good.
Good luck,
Danny
Previous Topic: GR Research
Next Topic: ART Array DIY ?'s
Current Time: Mon Nov 30 11:07:11 CST 2026
