Home » Audio » Speaker » DCX crossover installed
Re: Can tone be fixed with eq? [message #23855 is a reply to message #23851] Sun, 08 July 2007 17:43 Go to previous messageGo to previous message
Rick Craig is currently offline  Rick Craig
The problem could be due more to the recordings and not your system. If you set the Behringer mic at your listening position I would shelve down the response from 200hz on up (see my response to JP above). Most tonal quality issues can be solved with EQ but some of the differences I think are related to the driver design and cone material. JP's system has aluminum cones and the material stiffness can give the lower mid / upper bass area a slightly "dry" quality.
Previous Topic: JBL 2225H reconed as a 2235H?
Next Topic: JBL G-730 Diaphragm quest
Current Time: Sat Oct 31 18:05:41 CDT 2026
