Home » Audio » Speaker » Anyone Ever Tried These Drivers In Line Array ?
Re: Anyone Ever Tried These Drivers In Line Array ? [message #23808 is a reply to message #23798] Tue, 12 June 2007 17:13 Go to previous messageGo to previous message
Anonymous
>>There are zillions of these computer speakers popping up used
>>on Ebay.
I can't find any, unless you search 'monsoon' and you get three hits.
>>Why don't I see anyone but VMPS using this driver ?
Not many people build line arrays.
RE: ribbon. The driver you talk about is a magnetic planar, it's
not a real ribbon tweeter. Don't worry, even manufacturers of the
products generically call both technologies a ribbon when they
share nothing in common. lol
>>I see people talking about line arrays of super expensive Scan
>>Speak and Seas drivers, but never see these drivers even mentioned.
>>Shoot, I have seen pairs of the computer speakers sell on Ebay for
>>50 dollars. That means only 25 bucks a driver, certainly cheaper
>>then the expensive convetional drivers used in some line arrays.
You can use a quality $20 - $30 cone midrange driver in a line array
with great results. My budget array uses 49 cent buyout drivers. lol
You can use $100 - $200 midranges too. You can probably make the monsoon array work well too. But I'd buy one driver first to audition it and compare the sound to other drivers to get an idea
on where it stands.
>>Now, if you say these drivers are only usable to 500 to 600 hz,
>>HOW does VMPS cross over at 280 hz at only 6 db per octave ?
A commercial product doesn't mean it's engineered well in spite
of what the brand image tells you. The reason I DIY is because
I don't like store bought speakers, otherwise life would be so
easy just to talk into the store and buy something, you can take
up another hobby like fishing. hehehe
Hypothetical. What if you used that driver for 500hz - 10,000hz
operation. What are you going to use for low pass 500hz? What
are you going to use for >10khz ?
Lets assume that driver is indeed awesome and can play down to
500hz with authority, but has a weak top end, what are you gonna
do about it? Now you need another tweeter line, you need a midbass
line to cover from subwoofer to 500hz. You open up a new can of
worms.
On the other hand, you can take a simple $30 Dayton 6" midwoofer,
sealed and integrate with a subwoofer easy. Do you want to be a bass
maniac? Then port that Dayton midrange and tune to 45 - 55hz to get
more SPL. Use a $4 - $30 tweeter line and this simple 2 way loudspeaker can pretty much rule over commercial offerings that
cost in the $20k - $30k range, maybe more.
Previous Topic: Relationship Between X Max And Efficiency Questions
Next Topic: Dave Merrill has some health problems
Current Time: Tue Oct 15 15:54:58 CDT 2024
