Home » Audio » Speaker » 2 or 3 way line array
2 or 3 way line array [message #23793] Sat, 09 June 2007 18:38 Go to next message
j.luis is currently offline  j.luis
Im planning to build a array system but what way must to go 2 or 3 way line array . I only can image as can sound a system as this www.highemotionaudio.com has to offer .
Re: 2 or 3 way line array [message #23795 is a reply to message #23793] Sun, 10 June 2007 06:48 Go to previous messageGo to next message
Marlboro
Perhaps English is not your native language, as from your post I'm not sure what you are asking.
My preference is for a standard 3 way. I use a cross at 165 and 2500 with electronic 24 db/octave L-R.
If you want to see the system go to here: http://pub48.bravenet.com/photocenter/album.php?usernum=4095425731&album=48032
Others tend to prefer systems with ribbon or planar tweeters and larger woofers, that cross at 1600, and use a subwoofer for the bass, crossed at 60-80hz.
Could you be more specific in your question?
Marlboro
Re: 2 or 3 way line array [message #23796 is a reply to message #23795] Sun, 10 June 2007 10:17 Go to previous messageGo to next message
Hy. thanks english is not my native tongue but I try to comunicate .I want to mimic a line array as the pipe dreams with 24 mid-bass drivers and 42 dome tweeters and separate bass bins.To my surprise I found that the non cost object line array systems use dome tweeters instead of ribon units instance the afore mentioned pipe dreams and Mc intosh line arrays also the ephifany .the route regarding the X-over will be active 3 way Im looking for a Benhringer digital unity .I will post photos when the system become assambled at moment only have the towers with the tweeters .Again thanks for you reply .
Re: 2 or 3 way line array [message #23797 is a reply to message #23796] Sun, 10 June 2007 13:11 Go to previous messageGo to next message
Marlboro
If you email me at calipso@epix.net, I can share more information than I can do here. My line array is closer to the Pipe Dreams model than to some of the others.
Marlboro
Re: 2 or 3 way line array [message #23830 is a reply to message #23796] Sat, 16 June 2007 18:55 Go to previous messageGo to next message
hahax is currently offline  hahax
early Pipedreams used round planar drivers. Then Pioneer horn loaded ribbons were used. Finally the domes were used though they are custom and can't be used as singles. All worked very well and many of the chages were for practical as well as sonic reasons. The new Scaena speakers use planar tweeters and were designed by many of the Pipedreams designers. The use of many drivers to reduce the effort of any single driver is the affect that was desired.
Re: 2 or 3 way line array [message #23839 is a reply to message #23830] Thu, 28 June 2007 18:19 Go to previous messageGo to next message
oxford is currently offline  oxford
dummy
Re: 2 or 3 way line array [message #23840 is a reply to message #23839] Thu, 28 June 2007 19:37 Go to previous message
I'm mystified. Dummy as per what. At least be specific. As for my history it's correct. I know the designers very well on a personal basis. I know the history. Single words calling people names mean nothing.
Previous Topic: MV9D Speaker Parts
Next Topic: Array Tweeter Selection
Current Time: Fri Nov 06 04:27:45 CST 2026
