Better to stay ANALOG!! [message #23733 is a reply to message #23730] |
Sat, 12 May 2007 08:41 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Marlboro
Messages: 403 Registered: May 2009
Illuminati (1st Degree) |
So for only $300, more than the cost of the Behringer to begin with, you can upgrade it to outstanding so that all those conversions back and forth from analog to digital to analog to digital to analog can be done right? And remember that even if you do do that, then your CD player's DAC is probably the pits to begin with unless you own one of those $3000 players or paid someone $500 to convert your lowly cd player to some new high tech CD DAC. How about making one conversion from digital to analog on your CD player. Use an analog crossover instead to avoid all those stinkin' back and forth conversions, each one losing more and more of the low level signal. Try(brand spanking new): Ashly XR2001 Stereo 3-Way, or Mono 4- or 5-Way Active Electronic Crossover $539.99 or Rane: AC23B Active Crossover, Stereo 2 or 3-Way, Mono 4 or 5-Way $589.00 or Build it yourself: Marchland: XM44-3EZK EZkit, 3-way model. $ 960.0 ($1200 if they build it) Your choice. For the models over $600 new, I'm sure you'll hear a difference. Of course you will, when you remember that you paid so much more money, and everyone knows the more you pay the better it is! Marlboro
or ebay [message #23734 is a reply to message #23730] |
Sat, 12 May 2007 08:49 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Marlboro
http://cgi.ebay.com/RANE-AC-23-Active-Crossover_W0QQitemZ200108165188QQihZ010QQcategoryZ23790QQssPageNameZWDVWQQrdZ1QQcmdZViewItem or if you hurry: http://cgi.ebay.com/Rane-AC-23-Crossover-Good-Condition-Low-Reserve_W0QQitemZ160114585819QQihZ006QQcategoryZ23790QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Re: DEX2496 or DCX2496 [message #23735 is a reply to message #23730] |
Sat, 12 May 2007 11:28 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
I've read just about every thread on the DCX, the DIYA forum, Yahoo groups, people are going 'mod crazy' on this thing as if it has the black plague. Later, I bought one and did extensive audible tests with the analog pathways and pure digital pathways up to the amps, I can't find any real audible flaws with the sound no matter how hard I try to cannibalize the signal path. I've been into electronics and audio game for many moons, this is really a good piece of gear for $250. I think the mod people like to mod it because they can and it's cool, electronics folks are like that, they need to do a mod to be happy.The DCX is XLR input, to get the best low noise performance, feed a preamp signal that is higher than most home audio gear supplies, ie, home gear is typically 1v preouts. XLR is around 8v preouts. You can optimize the 'gain structure' by feeding it a nice preamp signal from an XLR source, ie Parasound Halo, certain B&K receivers, etc. It's not mandatory, you can drive it with a 1v source just to get started and play around, who knows you might like it alot like this. But there is room to upgrade if you wish. If you drive a home amp with DCX XLR outputs and your home amp is RCA input, there is a simple cable mod to lower DCX output gain so it won't drive your amp too high as it induces more hiss. Special XLR to RCA cable -6dB output gain; XLR Pin 1 = Shield ground => one RCA gnd. XLR Pin 2 = Positive balanced signal => RCA hot XLR Pin 3 = Negative balanced signal = don't connect I made my XLR to RCA connectors with a switch that connects pin 3 to pin 1 to allow selection of output gain, normal or -6dB. This simple cable mod worked nice when I connected the DCX to my Adcom 555 amp. I got less 'hiss' as gain is reduced. But now I drive DCX directly into the pro audio amps, XLR to XLR, no cable mod. I also use a Roland M1000 mixer [now discontinued], it's the volume control when using the audio system in digital pathway mode. This unit allowed to to easily test analog and digital pathways instantly for quick comparison. This is a nice piece of gear for $250, I have no idea why Roland discontinued it.
Certainly true...... Apex 220 & Fuzzmeasure 2.0.11, my choice. [message #23738 is a reply to message #23737] |
Sat, 12 May 2007 22:25 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Marlboro
That's certainly true. However, anyone who is building a line array should be willing to invest in a measurement system to tweak the system to its potential. I use a calibrated Apex 220, with preamp, connected to my Powerbook. On my powerbook I use Chris Liscio's great Fuzzmeasure software. current version is 2.0.11. I usually measure at the listening position rather than 1 meter from the speakers. Line arrays are kind of aways anyhow. And, of course, while its not currently in my "loop", I have a DOD 2/3 octave constant Q equalizer. Altho, modifying the crossover position and volume can serve as a kind of tone control modification. Tweaking in this way can be lots of fun and takes lots of time. I'm not currently set up for this, as I'm remodeling the room that my system is in. Marlboro
Adjustment TO YOUR NEEDS [message #23740 is a reply to message #23739] |
Sun, 13 May 2007 07:54 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to next message](/forum/theme/AudioRoundTable/images/down.png) |
Marlboro
JP, You may find, as THylantyr and I have, that you don't need to adjust very much, or that adjusting to YOUR taste is infinitely better than adjusting to some arbitrary assigned frequency response pattern. After all, all of us humans have different hearing of frequency response across the board with some dips and rises in our perception of sound, regardless of what is actually being presented by speakers or amplifiers. Right no I have a sinus infection in one ear and my total awareness of my system is vastly different from when I did not. Marlboro
no idea..... [message #23742 is a reply to message #23741] |
Sun, 13 May 2007 14:02 ![Go to previous message Go to previous message](/forum/theme/AudioRoundTable/images/up.png) ![Go to next message Go to previous message](/forum/theme/AudioRoundTable/images/down.png) |
Marlboro
I have no idea what the best thing to do is. My Rane and the DOD equalizer have phone plugs which I converted to RCA's. I would defer to someone more knowedgeable like Rick or Thylantyr. Marlboro
