Home » Audio » Speaker » Got my line arrays on a web photo center.....finally!
Got my line arrays on a web photo center.....finally! [message #23644] Mon, 23 April 2007 17:00 Go to next message
Marlboro
Click on the photos for a larger or complete version:
http://pub48.bravenet.com/photocenter/album.php?usernum=4095425731&album=48032
Marlboro
Awesome! [message #23645 is a reply to message #23644] Mon, 23 April 2007 19:53 Go to previous messageGo to next message
Awesome? [message #23647 is a reply to message #23645] Mon, 23 April 2007 22:01 Go to previous messageGo to next message
Marlboro
As awesome as they might look, I would assure you that the sound is much much more.
If the recording is even reasonable, I no longer even know about speakers, I get lost in the music, I find myself conducting, I keep saying "Wow", over and again. So many CD's, so little time. Even things like Creedence Clearwater Revival present stuff I never heard before. And listening to Renee Fleming singing "Summertime" by Gershwin is so heavenly that I get tears in my eyes.
Yeah....awesome. I was thinking this evening that I would enlarge the woofers to the ceiling in a large sonotube, and I kid you not, I found myself saying, that I couldn't do that because it would block the sound from the basses and harpsichord which were behind the cellos. Talk about depth of image!! I had to remind myself, that there wasn't a harpsichord back there behind the basses!
Marlboro
Re: Awesome? [message #23653 is a reply to message #23647] Tue, 24 April 2007 11:23 Go to previous messageGo to next message
What are you're x-over points on the midrange? It looks like there's quite a bit of space on the c-t-c spacing of them.
Yeah....AWESOME [message #23655 is a reply to message #23653] Tue, 24 April 2007 17:26 Go to previous messageGo to next message
Marlboro
The lower crossover to the woofers is at 165hz.
The upper crossover to the tweeters is at 2600. The center to center distance is exactly 5 inches. This sets the upper limit to: 13560/5= 2712hz as the maximum crossover to avoid THE BEGINNING OF comb filter distortion. I'm under that limit. There are other theorists who may suggest other limits, but this one works in practice.
The midranges are designed by Sammi of South Korea. They were designed to sell for about 16 bucks a piece, but Sammi could NOT find anyone to buy a three inch widerange speaker at that price. They have copper voice coils, paper-fabric composite cones, and 3.3 Xmax and are pretty flat in FR in the range that I use them. Sammi unloaded them in the buyout market for quite a bit below market value, and were happy to do that on their poor design/cost decision. In the large group, they only have to handle 5.8 % of the total midrange volume per channel. Additionally they are placed in separate 4 inch by 23.5 inch PVC closed tubes stuffed with 4 lb/cu ft fiberglass. Closed tubes have some unusual features which augment clarity in speakers that I won't go into now, but I tested them in boxes and in my tube design, and verified the clarity myself and with two audio observers. This also makes a difference. I could have put the midranges closer and had more them, but then I would have lost the considerable gain in using 4 inch PVC closed tubes. I have actually crossed lower than 2600, but haven't noticed a difference in sound between 2300 and 2600. Considering that 2300 will stress the tweeters more than 2600, and I hear no comb filtering at 2600, I go with that one.
I am using Dayton Neo 20FA's. These tweeters are the only dome tweeter of any quality that I am aware are available in the USA which by cutting the flanges can get the center to center distance below 1 inch and closer to .9. This has to be done, and if you look closely at the photos you can see the tightness. The keeps comb filter distortion in the tweeters above an inaudible(for me) frequency of about 15,000hz.
The normal crossover for this tweeter when ONLY one is used is 3500hz. However, this is a generalized number for a 2nd order crossover of 12 db/octave slope. Mine is a 24 db L-R electronic crossover. And instead of letting just one carry the load, 30 of them are carrying the load. Discussion about this tweeter on the Parts Express Audio forum(Dayton is the brand name for PE), puts the tweeter as low as 2200hz for a 48 db/oct slope, and easily do-able at 2600 for a 24 db slope when each one is only carrying 3% of the total frequencies as mine are. And of course, my crossovers are stable since they are electronic.
HOPE THIS HELPS YOU.
Marlboro
Just a thought on high frequency comb filtering. [message #23656 is a reply to message #23655] Tue, 24 April 2007 17:56 Go to previous messageGo to next message
Andy_G is currently offline  Andy_G
Just a supposition is all....
With tweeters say X" ctc, the combing that occurs at listening distance will be a sort of ripple in the reponse, with the troughs about X" apart.. now our ears are like 2" from top to bottom, so they will average out any variations within those 2", so maybe combing will not be audible once the tweeters are closer than about 2" ctc.
As I said, just a random thought.
Re: Just a thought on high frequency comb filtering. [message #23657 is a reply to message #23656] Tue, 24 April 2007 17:58 Go to previous messageGo to next message
Marlboro
Good thought. I wonder what JIM Griffin might say.....
Re: Just a thought on high frequency comb filtering. [message #23658 is a reply to message #23657] Tue, 24 April 2007 18:11 Go to previous messageGo to next message
my goodness, you mean it might not be as silly as it sounds ?
Re: Just a thought on high frequency comb filtering. [message #23659 is a reply to message #23658] Tue, 24 April 2007 18:17 Go to previous messageGo to next message
actually. at any particular frequency over say 15k, the combing would, I think, manifsted itself as a ripple in amplitude as you change vertical position. The ear would average this to an rms value (maybe), hence you get the apparent lowering in spl at high frequencies. Sorta makes sense, perhaps. That means that it could be counteracted by using tweeters with a rising response above say 15k.
Disclaimer, all this is pure conjecture. ;-))
Re: Yeah....AWESOME [message #23660 is a reply to message #23655] Wed, 25 April 2007 00:01 Go to previous messageGo to previous message
jphaggar is currently offline  jphaggar
Makes me want to build a pair !!!!!1 what is the electronic xover you are using ? How are the mids and tweeters connected ? If you dont mind giving some details , I could build a pair .
Thanks
JP
Previous Topic: Line Array Impedance Question
Next Topic: Reveiw of Merrill (DCA 4") drivers on 6 moons
Current Time: Fri Nov 06 04:03:10 CST 2026
