Home » Audio » Speaker » Use of multi-meter for measure impedance of lines Question..
Use of multi-meter for measure impedance of lines Question.. [message #23572] Mon, 19 March 2007 08:37 Go to next message
Elvis is currently offline  Elvis
I asked this question on the PE board, but I want to verify it here with people who actually build line arrays.
When I am done with the wiring for my mid range array, and also for my tweeter array, can I use a multi-meter to measure the impedance of the individual lines to verify that I'm within the appropriate impedance levels for my amps. I'm assuming that I will be using a separate amp for each line. And, when I use the tweeter check, I want to be sure that using it won't damage the tweeter portion of the array.
Can those who know how arrays work and multi-meters please answer also?
I want to know that I can check this before I start building it.
Elvis
Indirect answer [message #23574 is a reply to message #23572] Mon, 19 March 2007 19:11 Go to previous messageGo to next message
Aaron D is currently offline  Aaron D
Impedence is dificult to measure w/ a meter. If you want to accomplish (almost) the same thing, measure the DCR of an individual driver and use that spec to determine the desired value of whatever your series/parallel total should be. If the measured value varies much from the predicted value then someting is wrong in your wiring.
If you are just trying to get lucky and experiment w/ with different wiring variations w/o taking the time to calculate (or learning how to calculate) a practical wiring scheme then just make sure the DCR of you combo is above that of a sigle driver. This will not necessarily provide good performance but it will keep you from killing your equipment. Sorry if this portion of my answer seems off base but I have no idea how much experience you have w/ this kind of thing and I am trying to keep you out of trouble.
Aaron D
direct answer [message #23575 is a reply to message #23574] Mon, 19 March 2007 21:24 Go to previous messageGo to next message
Marlboro
AARON,
I think that Elvis is asking whether after do all the wiring based on a wiring diagram that he can have a double check. If that is the case then sure he can. Using the Excel program, one can easily find out the correct diagram of how many "series groups" have to be wired in parallel. But I know from experience that when wiring 17 speakers or 30 speakers, even with colors on all of them, it can get confusing. I wish that I'd thought of digging out my multi-meter and checking to make sure the total impedance wasn't below something my amp could handle. I just checked it about 5 times and held my breath.
Wiring in parallel has always been kind of weird to me anyhow.
Marlboro
Re: direct answer [message #23579 is a reply to message #23575] Wed, 21 March 2007 09:51 Go to previous messageGo to next message
Impedance from series wiring can be found easily with this formula:
Rt = R1 + R2 + R3 ...
Parallel wiring can be found with this formula:
Rt = 1 / ( 1/R1 + 1/R2 + 1/R3 ... )
Of course, this can only tell you the simple part of the impedance, and doesn't calculate the complex part. Impedance of a speaker is actually not a single value, but rather has peaks and dips. Actual impedance can be measured with a sine wave signal generator and an AC multimeter using a series resistor as a voltage divider. An easier way to do it is with a computerized measurement system like Speaker Workshop. That will measure impedance charts and much more.
Re: direct answer to Wayne [message #23580 is a reply to message #23579] Wed, 21 March 2007 10:35 Go to previous messageGo to next message
My problem is not the figuring out of the appropriate combination of series and parallel wirings.
I have an excel program that somebody sent me from PE Forum that tells me exactly what "groups of series speakers" have to be connected via parallel.
My problem is that after I have wired it to the best of my meager non-anal ability that I may have inadvertently wired one of the black wires to the red side of the parallel lines, or that I wired two red ones together in the series line.
I wanted to have a double check that I did it in an OK manner.
Elvis
Re: direct answer to Wayne [message #23581 is a reply to message #23580] Wed, 21 March 2007 11:54 Go to previous messageGo to next message
I see, or at least I think I do. You're saying you want to double-check your wiring, right? If so, I'm not sure I can recommend a short-cut. You can measure total impedance for a "sanity check" - If it's way off then you'll know something is wrong. For example, one would expect a series/parallel network of four 8Ω drivers to measure 8Ω total, so if it didn't you would know something is amiss. But there is no substitution for checking point-to-point connections. Even if you measure impedance and find it's right, you won't know that polarity is right for each driver without a response chart. Best to check your wiring, point-to-point.
Re: direct answer to Wayne [message #23582 is a reply to message #23580] Wed, 21 March 2007 13:46 Go to previous message
Anonymous
Even though I've been doing wiring forever and I feel confidnent the
first time around, I always triple check wiring by visual
inspection. For an array, there is no margin for error. Take your
time and check everything three times.
Previous Topic: possible blown woofer? help?
Next Topic: Cogent True to Life/Welborne Labs
Current Time: Mon Oct 26 05:30:59 CDT 2026
