Home » Audio » Speaker » Use of multi-meter for measure impedance of lines Question..
Re: direct answer [message #23579 is a reply to message #23575] Wed, 21 March 2007 09:51 Go to previous messageGo to previous message
Impedance from series wiring can be found easily with this formula:
Rt = R1 + R2 + R3 ...
Parallel wiring can be found with this formula:
Rt = 1 / ( 1/R1 + 1/R2 + 1/R3 ... )
Of course, this can only tell you the simple part of the impedance, and doesn't calculate the complex part. Impedance of a speaker is actually not a single value, but rather has peaks and dips. Actual impedance can be measured with a sine wave signal generator and an AC multimeter using a series resistor as a voltage divider. An easier way to do it is with a computerized measurement system like Speaker Workshop. That will measure impedance charts and much more.
Previous Topic: possible blown woofer? help?
Next Topic: Cogent True to Life/Welborne Labs
Current Time: Wed Sep 23 13:26:13 CDT 2026
