Home » Audio » Speaker » Anybody want to build a DIY IDS-25 clone (somewhat cheaply)?
My bias [message #23565 is a reply to message #23560] Fri, 16 March 2007 11:39 Go to previous messageGo to previous message
Marlboro
I don't think its necessary to purchase the best speakers in a line array since, as Bill Fitzmaurice says, almost every speaker is pretty flat at low volume. So, when you use a lot of them, the flatness at low volume stays, since you have so many to cover the frequency ranges.
I think you can design a quality array using Dayton Neo 20FA tweeters. I did, and I used 60 of them total. That's a huge number of tweeters to spread the sound through. I you use 8 planars on a side, that is a far cry from 30 domes, per side.
Additionally, if you use a midrange that retailed for 12-20 bucks each, again you will get high quality sound since EACH they don't have to play loudly. My Sammi's were a great buyout at $3.50 from a regularly priced model of 12-18 bucks(you don't get a 10 oz magnet and an X-max of 3.6 mm for 49 cents!). Other companies besides PE that also participated in the buyouts are now selling them for 7-10 bucks each. Fine little speakers. Going below those levels may get you an OK system, but below the level that I would consider appropriate for all the work involved. Buying a 49 cent NSB midrange is not appropriate for all the work involved in my opinion.
Always compare the quality to what you already have. I did.
Marlboro
Previous Topic: Back from Dallas and depressed ...
Next Topic: ART Array construction continues.... and a question
Current Time: Sun Oct 25 04:22:49 CDT 2026
