Home » Audio » Speaker » comb filter distorsion
comb filter distorsion [message #23510] Sun, 04 March 2007 09:15 Go to next message
j.luis cruz . is currently offline  j.luis cruz .
Hy .. how does sound comb filter distorsion ?
Re: comb filter distorsion [message #23511 is a reply to message #23510] Sun, 04 March 2007 13:12 Go to previous messageGo to next message
Marlboro
Comb lining will dull the highs and will be most noticeable in the lack of air (dull highs) especially as you move off axis. Essentially, the high frequencies are rolled off as the ensemble of the tweeter outputs don't add up but start to cancel. Now the ear is less sensitive in the upper octave (10-20 kHz) you may not observe the full impact of this effect. But if you compare to an array that is properly designed, then there is no comparison as the proper array will yield a more airy (and accurate) sound.
Jim Griffin on PE 11-21-06
Re: comb filter distortion [message #23512 is a reply to message #23511] Sun, 04 March 2007 13:16 Go to previous message
Marlboro
THE SAME THING CAN HAPPEN IN the upper midrange if you cross your midranges to high also, and this will be much more noticable and won't require a comparison with a "properly designed array" to hear.
Marlboro
Previous Topic: anyone tried equidistant spacing?
Next Topic: 1:1 throat area
Current Time: Thu Nov 05 03:33:33 CST 2026
