Home » Audio » Speaker » Art arrays are done
Re: Art arrays are done [message #23444 is a reply to message #23443] Tue, 13 February 2007 19:10 Go to previous message
The ART arrays were designed to a $350 total budget including the cost of building the enclosure. If you use the M-130's with a comparable quality tweeter I'm sure you will get better sound, but the total cost will go over $500.
Here are a couple of more upscale kits, one of which uses the M-130's.
http://www.rawacoustics.com/item__RA8_Speaker_kit,801.html
http://www.selahaudio.com/id103.html
(Scroll down to the Day Tek, whichs uses Dayton reference drivers with a Fountek ribbon tweeter)
Previous Topic: Thinking About Buying Infinity RS 1 B'S ?? Scared !
Next Topic: Newform R30 / Scan 8545 array
Current Time: Fri Oct 23 11:40:14 CDT 2026
