Home » Audio » Speaker » Inspired by the McIntosh XRT2K
Re: Inspired by the McIntosh XRT2K [message #23416 is a reply to message #23414] Fri, 26 January 2007 03:03 Go to previous messageGo to previous message
Attila is currently offline  Attila
You are right in your assumptions, but I think there may be a problem using BassBox in this way, as it apparently assumes parallel wiring of all drivers. That is fine with 2 drivers, but with 45 the impedance would drop way below the 'amplifier-up-in-smoke' level as each doubling of driver numbers will half the nom impedance, leaving you with a load of about 0.15ohm for 45 drivers. Not good!
If, on the other hand, you assume constant impedance (for 49 drivers that could be 7 parallel series of 7 drivers each), you only gain about 3db by doubling the number of drivers, or a bit more precise: 10*LOG(49), which is 16.9db going from 1 to 49 drivers. If the impedance due to your wiring goes down from 8ohm (single driver) to say 4ohm nominal, you will get an additional gain of 10*LOG((8/4);10), which is about 3db in addition to what the extra radiating area gave you.
Previous Topic: Needles a Great Success!
Next Topic: Word document for cutting flange of Neo Tweeters
Current Time: Thu Nov 12 03:30:19 CST 2026
