Home » Audio » Speaker » Inspired by the McIntosh XRT2K
Re: Inspired by the McIntosh XRT2K [message #23413 is a reply to message #23412] Thu, 25 January 2007 06:09 Go to previous messageGo to previous message
Attila is currently offline  Attila
At 120db from this I think there would be some cones flying! If my thinking is not completely off (that happens!), reaching 120db with 1 line of 45 drivers would require a total of 45000 watts - that is a bit more than my fuses can handle...
The 90db sensitivity rating for 1w/1m with 45 drivers is a bit misleading. This is a measure for the SPL with 1w energy dissipated for each driver. The SPL for 1w total energy dissipation does not change, that remains at 74db/1m (according to Zaph), only it is now generated by 45 drivers burning off 1/45w each. The real gain is in lower distortion and more headroom. It is more meaningful (although not very precise due to impedance variation over frequency) to use the SPL @ 2.83v/1m measure here, as 2.83v across all 45 drivers will produce around 90db/1m.
Anyway, you are right in that my number was too low, it should be around 103,5 max SPL with 20w/driver peak. That is actually less than 5db off the RD75, so this may not be so bad. More thinking required!
Previous Topic: Needles a Great Success!
Next Topic: Word document for cutting flange of Neo Tweeters
Current Time: Thu Nov 12 03:30:19 CST 2026
