Home » Audio » Speaker » Marlboro
Marlboro [message #23387] Thu, 18 January 2007 19:49 Go to next message
mickey is currently offline  mickey
I was wondering if you can share to me how you cut the flanges of your neo tweets? Do you have some pictures of them?
TIA
Re: Marlboro [message #23390 is a reply to message #23387] Fri, 19 January 2007 21:25 Go to previous messageGo to next message
Marlboro
Mickey,
I emailed you that I'll take some photos tomorrow and make up a word or a PDF document showing exactly what I did. To do it right you need a scroll saw. It could be a hand saw but it would take forever. I tried my band saw, and my radial arm saw; the first just didn't cut tight enough and the radial destroyed the little tweeter, ripping it apart. The scroll saw did the best job.
Marlboro
Re: Marlboro [message #23391 is a reply to message #23390] Fri, 19 January 2007 22:34 Go to previous messageGo to next message
Marlboro,
Thanks for your generosity. This would really help cut back on the pain I would have to go through to cut those flanges. It would probably encourage other DIYers to go the line array with dayton neo route when they see how you do it.
TIA
Re: Marlboro [message #23392 is a reply to message #23387] Mon, 22 January 2007 06:44 Go to previous message
Marlboro
I found that the little wooden jig I used is gone, so I have make another one, and the garage work room was pretty cold with the temperature outside at a balmy 22F. So i didn't get the pictures.
Have not forgotten and as soon as things warm up just a smidgen and my wife is available to take some photos, I'll make up the PDF document showing how to cut the flanges on the neos.
Marlboro
Previous Topic: 3 wire acoust out there!
Next Topic: Built Pi Midhorn
Current Time: Sun Oct 25 12:38:47 CDT 2026
