Home » Audio » Speaker » Hook up wire?
Hook up wire? [message #23355] Thu, 11 January 2007 18:08 Go to next message
Tom R. is currently offline  Tom R.
I am getting close to mounting and wiring up the drivers in my line array project and wonder if any one has a suggestion for internal hook up wire? Doing a rough
calculation I need about 70 ft between the pair. I have around $ 40 to $70 to spend on internal wiring, or should I just save the money and put something cheep.
Tom R
Re: Hook up wire? [message #23356 is a reply to message #23355] Thu, 11 January 2007 20:28 Go to previous messageGo to next message
14 gauge stranded from Walmart is fine. Comes in 100 foot rolls for about $30.
Marlboro
I prefer solid-conductor wire. I'd use the 18g. solid from multiconductor stuff from... [message #23357 is a reply to message #23355] Thu, 11 January 2007 20:38 Go to previous messageGo to next message
jeffreybehr is currently offline  jeffreybehr
...Home Depot/Loew's. I recall some is available in something called irrigation-system wire, and some communications wire is solid 18. If 18g. sounds a little thin to you, double it for 15g.
I had some old Audioquest speaker cable conductors and used those in 2 sizes to wire mine. That can be seen in this pic.
Re: Hook up wire? [message #23360 is a reply to message #23355] Fri, 12 January 2007 06:55 Go to previous message
If you want something better than zip cord but not costing too much, try Blue Jeans cables 12 ga Belden wire at 38 cents/ft. It's a two conductor, and there's an internal fiberglass thread that makes it easy to unzip to separate conductors.
Previous Topic: Damaged Wizzer Cone
Next Topic: internalhook up wire
Current Time: Tue Nov 03 12:09:23 CST 2026
