Home » Audio » Speaker » Needle Array
Re: Needle Array [message #23299 is a reply to message #23297] Mon, 06 November 2006 16:12 Go to previous messageGo to previous message
Danse,
My taper (5/3/35) and a uniform taper (4/4/4/4) run close--or equal--to an 8 ohms impedance. I personally would not suggest that you do what you are thinking as it would make a line array sound like a MTM and eliminate most of the near field array effects that I like. Plus if you are using my passive Needles crossover for your speaker, then it would need a change. On tapering I usually suggest no more than a 2:1 ratio for my tastes.
Jim
Previous Topic: RAW Acoustics HT3 - Speaker Kit Review
Next Topic: Acoustic treatment and the nearfield Question
Current Time: Tue Nov 03 20:54:00 CST 2026
