Home » Audio » Speaker » Needle Array
Needle Array [message #23292] Sun, 05 November 2006 16:10 Go to next message
Danse is currently offline  Danse
Were they power tapered?
Re: Needle Array [message #23293 is a reply to message #23292] Sun, 05 November 2006 19:17 Go to previous messageGo to next message
Yes, a 5/3/T/3/5 arrangement. The T is the ribbon tweeter in the array. They would also work with a 4/4/T/4/4 wiring.
Re: Needle Array [message #23297 is a reply to message #23293] Mon, 06 November 2006 13:38 Go to previous messageGo to next message
Thanks Jim!
Any thoughts on: half of 4/3/2/half of 2/T/half of 2/2/3/half of 4.
A little conserned at the Z = 3.3ohms, just wondering with a passive crossover the inductors should bring the Z up a bit, but would be stable enough for the amp.
Re: Needle Array [message #23299 is a reply to message #23297] Mon, 06 November 2006 16:12 Go to previous messageGo to next message
Danse,
My taper (5/3/35) and a uniform taper (4/4/4/4) run close--or equal--to an 8 ohms impedance. I personally would not suggest that you do what you are thinking as it would make a line array sound like a MTM and eliminate most of the near field array effects that I like. Plus if you are using my passive Needles crossover for your speaker, then it would need a change. On tapering I usually suggest no more than a 2:1 ratio for my tastes.
Jim
Re: Needle Array [message #23302 is a reply to message #23299] Tue, 07 November 2006 05:56 Go to previous message
Thanks again Jim
Previous Topic: RAW Acoustics HT3 - Speaker Kit Review
Next Topic: Acoustic treatment and the nearfield Question
Current Time: Fri Aug 02 03:16:59 CDT 2024
