Home » Audio » Speaker » Rocky Mountain Show
I'm sure they sound great; I don't doubt that. [message #23256 is a reply to message #23255] Fri, 27 October 2006 18:16 Go to previous messageGo to previous message
Marlboro
You're not listening.
I've made it clear that you can have a pretty dynamic set of sounding speaker from a 50 speaker 3.5 inch array. I've no doubt that they sound great. Geez!! My own array with the 17- 3.5 inch wide range speakers per channel sounded fabulous. But then I added the 30 Dayton Neo tweeters perr channel, and the high end that I thought sound great with just the 3 inchers suddenly seemed dead without the tweeters, and then I added the two 12 inch DVC 15 mm Xmax woofers and the bass was also fab. And my total system including the electronic crossovers, the pre-amp, and the 3 power amps, and constant Q equalizer, didn't exceed about $1700. No where near 18,000 bucks.
Does anyone know what brand 3.5 inchers he's using for them?
Marlboro
Previous Topic: Wire gauge to wire up all those speakers.
Next Topic: RAW Acoustics HT3 - Speaker Kit Review
Current Time: Tue Nov 03 16:48:31 CST 2026
