Home » Audio » Speaker » internal pressure
Re: internal pressure [message #23224 is a reply to message #23221] Tue, 10 October 2006 11:32 Go to previous messageGo to previous message
Anonymous
You will find a million recipes on cabinet deadening that confuses
everyone.
The basic rule is: A heavy wooden box well braced gets you
closer to the goal of making a dead cabinet.
You can do whatever you want to achieve this goal. Thick wood,
tiles on the inside, sand, concrete, composites, kitchen sink.
The problem is easy to solve when you are building a small
speaker box as you don't care if the speaker box weighs 50 - 100
pounds. When building a line array, it's a hard pill to swallow
that you might need a 500 pound cabinet to solve the problem to
your satisfaction.
You need to find a compromise, weight vs. performance. It's your
call.
The problem is easily solved with 1.5" thick MDF cabinet walls +
internal bracing. You need excellent bracing methodologies and
you can use plywood bracing to keep it lighter, but still a very heavy box.
Replace the 1.5" MDF with 1.5" plywood and you cut your cabinet
weight in 1/2, but performance is also reduced, catch 22.
A hybrid 3/4" MDF + 3/4" plywood is another choice, better performance than 1.5" plywood, but not as good as 1.5" MDF.
http://home.pacbell.net/lordpk/robarray/Rear_chamber-2.JPG
Example; This line array is 3/4" oak plywood. Four isolated chambers, 3 pieces of wood to make those chambers and to
brace the cabinet. To keep the weight down and to make
a dead box, I installed smaller 12" x 12" pieces of 5/8" MDF to
every wall in each chamber except the front baffle. I could have
used 3/4" + 5/8" lamination but I chose this method to trim weight.
After the build, the hammer test revealed that each chamber can be improved as the ringing wasn't as good as I wanted. To solve this,
a 1" dowel was inserted in each chamber to couple the left and right
sides of the cabinet.
I don't see any reason to use sand, or to add tiles because in the end, the cabinet will be heavy and to get a heavy cabinet you
can just start off with thick walls with bracing and the construction
project becomes easier. Fine tune the cabinet later with dowels or
whatever piece of wood.
Previous Topic: Questions about box tuning F3, F10, etc.
Next Topic: Fun with Vintage Speakers
Current Time: Thu Nov 05 21:58:35 CST 2026
