Home » Audio » Speaker » What are the most important T/S characterisitics in an array speaker?
What are the most important T/S characterisitics in an array speaker? [message #23152] Sat, 02 September 2006 08:22 Go to next message
Gene is currently offline  Gene
Since array designs tend to smooth Frequency response, and reduce distortion, it would appear that these are not the most significant characteristics when looking for DIY speakers to put into them.
What are the most important ones?
Perhaps sensitivity? High x-max? High Q's for a sealed box? transient response?
What do you think?
Gene
Re: What are the most important T/S characterisitics in an array speaker? [message #23159 is a reply to message #23152] Wed, 06 September 2006 07:46 Go to previous message
Marlboro
If you had to choose? low distortion. This is why many Dayton RS models beat the competition because of low distortion levels.
Frequency response smoothes with multiple speakers and is affected by the room anyway, and often needs equalization. But you can't make high distortion go away.
Marlboro
Previous Topic: 2006 Iowa DIY Speaker Event email list...
Next Topic: Listening distance
Current Time: Fri Nov 06 22:01:47 CST 2026
