Home » Audio » Speaker » Is it my imagination .....OR
Re: SPL measurement Formula? [message #23151 is a reply to message #23150] Wed, 30 August 2006 19:16 Go to previous message
Sure, you can always measure in-room and if you want to know what to equalize for, that's important information. One extra tidbit to consider is that in-room response is different at different places in the room. Equipment setup, room treatments and EQ all depend on what areas in the room are desired to have best response.
When making measurements for loudspeaker comparison, as the 1W/1M SPL figure is generally applied, tests should be made in an anechoic environment. Measurements made outdoors or in an anechoic chamber are used for comparing loudspeakers, since they remove environmental influence.
Previous Topic: Bose 901 recycle?
Next Topic: OPen baffle designs
Current Time: Mon Nov 16 06:38:10 CST 2026
