Home » Audio » Speaker » Is possible "near field" bass response using only 4 drivers ?
Is possible "near field" bass response using only 4 drivers ? [message #23110] Thu, 17 August 2006 18:50 Go to previous message
Renato is currently offline  Renato
Dears,
My english is to bad for write, but I will try.. I read without
problem!!!!
I already finished this Line Array and the sound is very..very good,
fabulous... but, the MID of 4" have a FS at 80hz and the result is a
bad, bad bass response.
http://www.mrweb.com.br/fvm/laf2/
I use active crossover and for bass, I finished this subwoofer:
http://www.mrweb.com.br/fvm/sumario/
But now, I think in build 2 modules for bass response in stereo mode, with this
excelent MID (FS 34hz) to work between range 34hz to 200hz
http://www.mrweb.com.br/fvm/akron/
The BIG question is:
Is possible have "near field" bass response using only 4 drivers in a
tower of 1,80m ??????
Because distance C-to-C will be 60cm and this distance is equal to one
wave at 573hz. 1/2 wave is 286hz....
Thanks,
Renato - Brazil
Previous Topic: Vintage RCA LC9A's Horn Speakers
Next Topic: Lower the crossover, the wider the sound stage?
Current Time: Sat Oct 31 08:00:47 CDT 2026
