Home » Audio » Speaker » Fredarrays
Fredarrays [message #23092] Tue, 01 August 2006 13:43 Go to next message
Fixxer is currently offline  Fixxer
I´m interested in building the Fredarrays with Fountek ribbons, are there any plans available?
TIA, Fixxer
Re: Fredarrays [message #23093 is a reply to message #23092] Wed, 02 August 2006 14:43 Go to previous messageGo to next message
Fixxer,
If you mean the arrays built by Fred Thompson, then you should contact Rick Craig at Selah Audio for details. Fred worked with Rick on his speakers. Rick supplied the plans and parts while Fred built the cabinets. Rick can supply parts kits (you build the cabinet) through turnkey speakers (shipped fully assembled in furniture quality cabinets).
Jim
Re: Fredarrays [message #23094 is a reply to message #23093] Wed, 02 August 2006 15:27 Go to previous messageGo to next message
I bought the XT-8 array kits from Rick. With a kit whose drivers and crossovers cost more than $3K I decided it would be best to rely on a competent speaker designer to do all the design and testing work. I would still advise others who are building a serious line array to do it this way.
I also designed and built the Fredarrays. These are very different from the XT-8s'. The object of this exercise was to find out how inexpensively I could build a line array that actually sounded good. Building on a budget requires some serious compromises, including inexpensive midbass drivers and a point source tweeter. The downside of the inexpensive midbass drivers is heard mostly in the midrange - $15 drivers just don't do midrange as well and high quality drivers. The disadvantage of the point source tweeter is that the speaker must be voiced for the listener to be seated a specific distance from the speaker. In spite of these disadvantages I believe I got good results for the money spent (less than $500).
I'll describe the Fredarray II since it was an improvement over the original. The nine Fredarray midwoofers were Silver Flute W14RC25-08's, available from Madisound (for $11.25ea back then when bought in quantities of 12 or more). The price has gone up a bit, so you should check with them to find out their current quantity discount price. The nine midwoofers were enclosed in a 61" tall enclosure which was internally divided into three separate chambers, each holding three drivers, with a 3" port. I didn't keep a record of the dimensions, but the internal volume for each chamber should be 1.3 cu ft, with a 3" by 3.75" long port. Sorry, but I don't remember the details of the crossover. You would need somebody with the necessary software to design it for you. The Silver Flute woofers weren't bad, especially for the price, but much better drivers are available today for a bit more money.
Rick Craig has designed a line array using nine 6" Dayton RS150 drivers in a sealed enclsoure, or eight 7" RS180 drivers in the ported version, along with a single Fountek ribbon tweeter. Last time I checked the kit, with assembled crossovers, sold for $800/pr. This is about what you would pay if you bought the parts yourself. You can see a picture of the DayTek at the Selah Audio picture gallery.
This is the way I would go if I had it to do all over. With the DayTek you will be getting a very good sounding speaker that you'll not feel the need to upgrade. Go to the link below and scroll down to the Day Tek for more information. Also, don't hesitate to call Rick.
Re: Fredarrays [message #23095 is a reply to message #23094] Wed, 02 August 2006 15:56 Go to previous messageGo to next message
Fred,
Thanks for correcting my fuzzy memory/thinking on the Fredarrays. That approach is a excellent introduction to a line array and works well if most of your listening is in or near a specific location. The Day Tek approach is a good one for folks who want to get their line array building feet wet yet not sink $2000 into ribbon tweeters.
Jim
Re: Fredarrays [message #23098 is a reply to message #23094] Thu, 03 August 2006 02:22 Go to previous message
Ok, I see. Well, thanks for the advices, I shall do that.
Previous Topic: TC Sounds Array components for DIY
Next Topic: Martin King subwoofer in AudioXpress
Current Time: Thu Nov 05 16:27:17 CST 2026
