Home » Audio » Speaker » ESG1 Can I use it for an array?
ESG1 Can I use it for an array? [message #23029] Sat, 24 June 2006 17:24 Go to next message
tolits is currently offline  tolits
Hi,
I have a pair of Aurum Cantus G1. Will it work for an array. I am planning of placing it in the middle of 8 5 inch peerless loudspeaker(sale page of Madisound).Is it a bad idea? TIA
Re: ESG1 Can I use it for an array? [message #23033 is a reply to message #23029] Tue, 27 June 2006 14:28 Go to previous messageGo to next message
The ESG1 is the Aurum Cantus G1. It is an excellent ribbon tweeter. While I have never used the G1 in a design, I have used the G2, G2si, G3 and G3i-130 variants in various designs.
My Needles array used 16 Tang Band W3-871S and a single A-C G3 ribbon per side. As with any line array of woofers and a point source single tweeter, you have to design the crossover to optimize the sound at the listening distance. This is because the array will operate in the near field and will have 3 dB per doubling of the distance from the array soound fall off. Conversely, the single tweeter will have sound fall off of 6 dB per doubling of the distance. For the Needles I used a slight power taper of the small midrange woofers to balance the sound with the ribbon. Now the G3 (as well as the G1) has limited vertical sound dispersion so the power tapering of the array helped to anchor the sound for a sitting listening position. The bottom line is that the Needles came out with excellent sound for its design. I suspect that your G1 and woofers design has the potential to be successful.
Now a near field line array with full length woofers and tweeters will make line array full room any position magic better than the Needles, the cost and size of the array is certainly larger.
Re: ESG1 Can I use it for an array? [message #23034 is a reply to message #23033] Wed, 28 June 2006 00:18 Go to previous message
Thanks Jim. Your reply encourages me to go for it.
Previous Topic: beautiful speakers.
Next Topic: Wharfedale D-60E
Current Time: Fri Oct 11 03:46:56 CDT 2024
