Home » Audio » Speaker » Dome tweeter in the back of line array
Dome tweeter in the back of line array [message #22998] Wed, 10 May 2006 13:54 Go to next message
JP Haggar is currently offline  JP Haggar
Does adding a dome tweeter in the back of a line array facing the back wall add some space effect ?
JP
Re: Dome tweeter in the back of line array [message #22999 is a reply to message #22998] Wed, 10 May 2006 21:27 Go to previous message
JP,
Genesis has a few dipolar/bipolar arrays that use a line of both rear and front facing dome tweeters but they are trying to maintain the dipolar effect above where the their big planar tweeter rolls off.
Frankly, I don't think that you need it. A single dome tweeter would not keep up with a line of tweeters on the front side--too much sensitivity different. You would need to dupicate the line on the front side of the box.
Bottom line is that a properly designed line array doesn't need a rear facing dome. I suggest that you focus on designing a good monopolar array. That would be enough to blow you away with spacey sound.
Jim
Previous Topic: Update of diyhorn
Next Topic: Need advice on cabinet choice for JBL E120
Current Time: Mon Nov 02 12:09:04 CST 2026
