Home » Audio » Speaker » Full range drivers in line array?
Re: Full range drivers in line array? [message #22933 is a reply to message #22930] Sun, 22 January 2006 14:20 Go to previous messageGo to previous message
Linc,
I don't support Bill's rule of thumb as an always true result. The best answer is to measure the performance of the array. This is because the array performance depends upon the overlap of the radiation patterns of the individual drivers (also whether you are in the near and far field). I'm finding that even for well behaved individual drivers that the array effects are hard to predict without measurements so rule of thumb thinking isn't always valid.
Note that some drivers--most notable are ribbon and planar tweeters--have reduced vertical axis pattern overlap vs. frequency. Hence, little vertical radiation interferences or mutual coupling occurs between the arrayed drivers. Arraying doesn't really impact the bandwidth for this case. Therefore, Bill's rule doesn't apply for this example.
Jim
Previous Topic: Help Wanted
Next Topic: Time Alignment - Horn/Compression & Woofer
Current Time: Sun Sep 13 04:18:24 CDT 2026
