Home » Audio » Speaker » Full range drivers in line array?
Re: Full range drivers in line array? [message #22932 is a reply to message #22930] Sun, 22 January 2006 09:18 Go to previous messageGo to previous message
I haven't stacked and measured boxes to find out for sure, but in theory it should work that way. When the weather allows I'll have to do so and see. Pro-sound is a different animal, the key there is minimizing the size of the frames between horn mouths, and that's accomplished by using multiple elements on multiple throats that converge into a single mouth. Then the only obstacle to integration is the size of the frames separating the individual cabinets, but at the distances involved between the source and the audience any lobing pretty much has disappeared at the listening positions.
Previous Topic: Help Wanted
Next Topic: Time Alignment - Horn/Compression & Woofer
Current Time: Fri Oct 16 17:22:31 CDT 2026
