Home » Audio » Speaker » please advice: 8 drivers, 95dB, 6ohm+
please advice: 8 drivers, 95dB, 6ohm+ [message #22900] Wed, 04 January 2006 09:31 Go to previous message
Dav is currently offline  Dav
To the LA gurus out there:
I'd like to build a quasi array using 8 5" drivers and a single dome tweeter at its center. I've read Jim's paper and Im stuck with achieving the following goals:
- 8 drivers per side
- roughtly 95dB efficiency
- minimum 6 ohm load
The drivers i plan to use have 86dB eff each @ 8ohms.
Doing the basic math described in Jim's paper, I 'best' I can do is 4 parallel groups totalling 98dB and 4 ohms.
The only solution I can think of is to add series resistance (4ohms) to get down to 95dB and 8 ohm load.
My questions are then:
Is this a acceptable solution?
Is series resistance a good approach?
If so, should I use several equal resitors in parallel for proper resistor/power managememt?
Is there another option/solution?
Thank you all in advance!
Regards
Dave
Previous Topic: Advice please
Next Topic: Could this be the perfect OB driver???
Current Time: Sat Nov 28 18:29:04 CST 2026
