Home » Audio » Speaker » New Cheap Quasi Line Array
Re: My Advice About DIY Line Arrays [message #22861 is a reply to message #22858] Wed, 30 November 2005 11:43 Go to previous messageGo to previous message
Anonymous
To add;
I built a NSB/PT2 line array last summer. 49 cent midwoofers that
were modified, 16 per tower and 10 Dayton PT2 planars per tower
{$25 ea.)
While I consider this a budget line array, the plan was to make
'high end' sound and I think I achieved this as I auditioned high end store speakers and I wasn't too thrilled. The point is, while
the system is using 49 cent midwoofers and $25 tweeters, what really
gets you cost-wise is all the misc. costs that add up.
I itemized about 95% of the project on a spreadsheet counting every
screw, rags, gloves, nails, tools, glue, stain, magnets, plywood,
mdf, solid oak pieces, sandpaper, terminals, wire, solder,
chemicals, Acousta-stuf, poly batting, turntable, skidpads,
rope caulk, sanding sealer, liquid nails, bondo, etc., and the
project cost about $2k to make from scratch taking into account all
the stuff needed.
While DIY is cool, driver cost alone will not be a good judge on
project cost. Driver cost for this project was;
midwoofer = 32 * 49 cents {plus $1 shipping per driver} = $47.68
tweeter = 20 * ~$25 = $500
Driver cost = ~$547.58
Materials = ~ $1450
If I went 'cheap' on material costs, then the sound I get out of
the system would not be as good. 'Sum of all parts' is what makes it sound good including construction method and materials used.
Previous Topic: Any thoughts on this driver?
Next Topic: Interesting quote
Current Time: Tue Nov 03 03:54:15 CST 2026
