Home » Audio » Speaker » Going from 3 to 12 tweeters...
Going from 3 to 12 tweeters... [message #22796] Sat, 27 August 2005 10:07 Go to previous message
skaloumbakas is currently offline  skaloumbakas
Hi,
I am using the Genesis 300 speakers which are using 3 tweeters on the front (2 mid/high tweeters and one super tweeter between them)
Question A:
- Would you encourage me take the plunge and go for 12 tweeter in array (all the same no supertweeter)? It will now look like their Genesis 201 latest model and the tweeter array will have a 45" height.
or...
- It is not worth the cost of ordering the extra tweeters and x/o (from Genesis) and the work to make the extra holes?
______________________
In case I stay with the 3 tweeters...
The configuration of them is:
t - st (ear level) - t (symmetry)
Question B:
- Should I change their relative position to:
t - t (ear level) - st (asymmetry)
to avoid comb filtering with the mis/high tweeters (as theory says, I do not have a clear audible indication for that). They are now at 8" center to center distance and getting them close, they will be at 4" distance (those tweeters are working f/ 3.6Khz - 8 or 10Khz, I am not sure...)
- Ofcourse, if I change, the supertweeter will loose its ear level height, because a mid/high yweeter will take its place...
My listening position is at 3.75 m. if that helps.
Thanks in advance
Christos Skaloumbakas
Previous Topic: Why do they cost so much??
Next Topic: Fostex 167E distortion
Current Time: Mon Nov 09 20:21:20 CST 2026
