Home » Audio » Speaker » Line Array woofer system
Line Array woofer system [message #22754] Fri, 29 July 2005 08:35 Go to previous message
eric j. is currently offline  eric j.
I was in discussion recenty with a friend about shifting my sub woofer system on the 2 way array that I'm building, to a full 3 way array with a line source woofer array too.
To keep the cost down I would use $11.25 Goldwood 7 inch poly woofers(fs=35), and use four of them per side in a sealed design, to keep the bass tight. Modeling on WIN ISd, I would need a 1.5 cu ft box for each. To save on weight, I would use 12 inch sonotubes with 3/4 inch MDF end plugs, and lots of fiberglas fill.
Crossover would be at about 200hz. The modeling shows it ruler flat to 40hz, down 4 db at 30hz and down 7 at 25 , which would have to be equalized out(system already has active crossovers and a DOD constant Q equalizer.)
What do you think?
Previous Topic: Great Plains Audio 704-8A quick notes
Next Topic: Looking for line array people
Current Time: Thu Nov 26 09:32:52 CST 2026
