Home » Audio » Speaker » Gumby Mk II ! progress pic !!
Gumby Mk II ! progress pic !! [message #22725] Sun, 17 July 2005 15:23 Go to next message
Andy G is currently offline  Andy G
for use with a sub-woofer.
Re: Gumby Mk II ! progress pic !! [message #22726 is a reply to message #22725] Mon, 18 July 2005 05:46 Go to previous messageGo to next message
Those are really cool looking, Andy! What speakers did you use? How does it sound?
Re: Gumby Mk II ! progress pic !! [message #22730 is a reply to message #22726] Mon, 18 July 2005 21:10 Go to previous messageGo to next message
Uses 12 x Vifa BC11SG a side + Peerless Horn tweeter..
requires a sub, but when combined with one it can do the whole gammet from soft highly detailed classical or acoustic work... right up to obnoxiously loud rock.. if the sub(s) can keep up !!!
I think it works out at around 97-98 dB sensitivity, with a rms power rating of over 200w.. so they can get VERY loud !!!!
Re: Gumby Mk II ! progress pic !! [message #22731 is a reply to message #22730] Tue, 19 July 2005 06:37 Go to previous messageGo to next message
That's cool, Andy. I like!
Re: Gumby Mk II ! progress pic !! [message #22732 is a reply to message #22725] Tue, 19 July 2005 08:49 Go to previous messageGo to next message
Why did you only use one tweeter per side? Are they infonite baffle, or are they in boxes? Can you post pictures of the sides and back?
eric j.
Re: Gumby Mk II ! progress pic !! [message #22733 is a reply to message #22732] Tue, 19 July 2005 16:48 Go to previous messageGo to next message
Using lots of tweeters requires a second column next to the mids, and the whole extra cost of DECENT tweeters (not 20c buy-out) would make it too difficult finanicailly.. The single ni sensitivity tweeter actually works very well in the normal-large listening room situation
The cabinet is actually a U frame and very easy to make.. here is an early picture
Re: Gumby Mk II ! progress pic !! [message #22734 is a reply to message #22733] Tue, 19 July 2005 17:33 Go to previous messageGo to next message
Yeah.....I forgot. You are in AU. You really don't have access to Part Express's DAYTON ND20TB-4 REAR-MOUNT 3/4" NEODYMIUM DOME TWEETER for $4.10 US$. see: http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=275-035
Shipping would eat you alive.
If you had had that access, would you have chosen them over the horn tweeter, or would you have purchased as horn of similar value($61 US$)? Having just done the same I chose the 15 tweeters over the $61 horn.
Re: Gumby Mk II ! progress pic !! [message #22735 is a reply to message #22734] Wed, 20 July 2005 16:22 Go to previous messageGo to next message
There is also the problem of where to put such a line of tweeters, without ruining the aesthetics !!
The single Hi-eff tweeter works very well, btw !!!
And you know that to me ALL rectangular boxes are Yuck !!!!
I actually cringe whenever I see those rectangular monoliths with a row of tweeters next to a row of woofers..... it assaults my sensibilities !!!
Where's the imagination guys !!!!!
An Assault on Your Senses [message #22736 is a reply to message #22735] Thu, 21 July 2005 05:41 Go to previous messageGo to next message
Yuck!! I suppose I'll have to give them away. What was I thinking:)
http://fredt300b.smugmug.com/gallery/132721/1/27073926
Re: An Assault on Your Senses [message #22737 is a reply to message #22736] Thu, 21 July 2005 06:18 Go to previous messageGo to previous message
Yeah , I guess so.. Send em here, I'll rebuild those BOXES for you
Or perhaps, I could say that you obviously weren't thinking when you built them like that, just operating on automatic.. ;-P
just like a NORMAL person would !!!!
Oooooo... I see a war brewing here ;-))
Previous Topic: Opinion on the Fe127e
Next Topic: Speakers
Current Time: Fri Nov 13 07:35:14 CST 2026
