Home » Audio » Speaker » Sealed compartments
Sealed compartments [message #22611] Tue, 03 May 2005 15:33 Go to next message
greenie512 is currently offline  greenie512
This is a follow on thought to my posting below.
Is there any advantage/disadvantage to creating sealed compartments for my speaker groups in an array or should I leave it as one long (well braced) box.
Cheers - Phil
Re: Sealed compartments [message #22613 is a reply to message #22611] Wed, 04 May 2005 06:44 Go to previous messageGo to next message
Phil,
It probably does not matter for a sealed box with the assumption that the box is well braced. I insert braces/shelves in my boxes primarily to help the rigidity of the enclosure and to brace the structure.
If your box was vented, I would suggest that multiple ports located near the drivers would be better than a single port. Separate ports would help distribute the air load on each driver.
Jim
Re: Sealed compartments [message #22614 is a reply to message #22613] Wed, 04 May 2005 06:57 Go to previous messageGo to next message
Jim - just the man. Was originally doing your suggestion but took it one stage further to a solid shelf? will go back to straight bracing and do muliple ports also.
While your here, could I get your opinion on power tapering. Could you look at my ealier post below and make any comments you think are saliant.
Cheers - Phil
Re: Sealed compartments [message #22618 is a reply to message #22614] Wed, 04 May 2005 09:59 Go to previous message
taylor is currently offline  taylor
FYI, Heres an array with separate compartments and tiny separate ports.
http://www.bottlehead.com/valve/whamodyne%20files/page8.html
taylor
Previous Topic: proac clones
Next Topic: Yamaha NS-1000M
Current Time: Sun Oct 25 01:28:16 CDT 2026
