Home » Audio » Speaker » K1840 for consultation
K1840 for consultation [message #22603] Sun, 01 May 2005 20:38 Go to next message
greenie512 is currently offline  greenie512
It’s public holiday in Australia and I’ve been dreaming up my next project when I haven’t finished the current one – as you do?
I’ve decided to try a Line Array for 16 drivers per cabinet. I’ve put a brief outline/sketch of my proposal on my web site – check out: -
http://www.greenie512.net/greenie512/html/k1840__new_project.html for details.
Am I mad/missing something/should be considering???? – all input welcome gratefully accepted.
Re: K1840 for consultation [message #22604 is a reply to message #22603] Mon, 02 May 2005 09:18 Go to previous messageGo to next message
With those speakers you have a cone break-up modes at 7khz you'll need to tame this down, so more than likely you will need a x-over and those tweeters. Also an array this size you will have to power taper it otherwise your going to get sound bloom as they call it from sitting to standing positions.
HTH
Bill W.
Re: K1840 for consultation [message #22605 is a reply to message #22604] Tue, 03 May 2005 07:41 Go to previous messageGo to next message
knowing nothing about power tapering I’ve just had a quick “sqizz” at Jim Griffin’s white paper. I was thinking about 16 drivers per box but to taper I think I’ll increase this to 17: -
Parallel groups – 3/4/4/6
Series connections- 8,9,10/6,7,11,12/4,5,13,14/1,2,3,15,16,17
Speaker 1 at base – 17 at top
That I can cope with understanding and I can calculate impedance for uniform parallel branches but could you let me, explain or point to a resource to calculate the formula of the above combination (8 Ohm drivers).
Cheers - Phil
Re: K1840 for consultation [message #22606 is a reply to message #22605] Tue, 03 May 2005 10:03 Go to previous messageGo to next message
I ran your combo looks like a good power taper for impedance but for the sound, don't know. Your impedance is going to be at 8 ohms with that wiring. The only difference is I'd wire them a little different.
Parallel groups - 6/4/4/3
Series connections - 1,2,3,4,5,6/7,8,9,10/11,12,13,14/15,16,17
Speaker 1 at base - 17 at top
I'd try this for starters, like on my line arrays this is about the way there wired, you just have to build and test, listen, make changes test again, etc.etc. until you get the tapering the way you want it.
HTH
Bill W.
Re: K1840 for consultation [message #22607 is a reply to message #22603] Tue, 03 May 2005 10:20 Go to previous messageGo to next message
Anonymous
According to your design goals;
*Ken isn’t into high quality audio in any big way
*it plays loud (high SPL)
*it plays LOUD .... etc etc etc
*Therefore extreme high quality is not an issue here
The line array of those pioneer 4" midranges will do the trick.
Since there is no low pass crossover you should at least tame
the driver to make it sound good. A simple $5 modification will do
the trick. Coat the cone with 4 coats of lacquer.
To improve power handling there is another mod, but it cost $30-$40
and you have to inject about 5 - 10 tiny drops of ferrofluid on the
voice coil using a syringe. I've done alot of ferrofluid tests with the dust cap off and the only issue with no dust cap is -> the dust.
lol -- dust will clog the fluid and gum up the driver over a long
time. It's best to find a way to inject the fluid and keep the cap
on. The fluid boosts power handling alot, I drove 400 peak for about
10 minutes before the driver literally melted and fused the coil
stuck. The SPL was mad just from one driver, imagine the array. /hehe
If you don't use a high pass crossover there is a good chance
of destroying those drivers with excess bass. You shuold cross
them over ~100 - 200hz at least. To get good bass out of the design
you can port the midranges and tune it to 100hz to give you a nice
6 - 9db boost centered around 100hz.
I'm working on an array with those drivers and I have a diary
here;
http://www.caraudioforum.com/vbb3/showthread.php?t=210115
Essentially, the drivers will be modded with lacquer and phase plug
and maybe ferrofluid, unsure yet.
I uploaded some 'sneak peak' low quality pics and video here
of my current project I'm doing for a friend. http://www.caraudioforum.com/vbb3/showthread.php?t=216773
If you want to improve the sound alot, add a center horn {ie, compression driver w/lense}. Eminence would offer good results,
but PE has cheaper horns you can use. Here is a concept of a 3 way
line array with a center horn, those midranges, and some 7" woofers.
http://home.pacbell.net/lordpk/misc/Feandil-2.GIF
This design was built recently and the builder loved the sound,
he said it was awesome especially with that Eminence horn. He had
to lpad the horn. He powered his array using a QSC 2450 pro amp.
If you want more info on that project I can give you his email address
if you have specific questions. Send me an email to my hotmail.com
address, use thylantyr as the name.
Re: K1840 for consultation [message #22608 is a reply to message #22605] Tue, 03 May 2005 10:22 Go to previous messageGo to next message
Anonymous
Don't worry about power tapering. Keep the wiring simple.
Remember your design goals.
/hehehehe
Re: K1840 for consultation [message #22609 is a reply to message #22606] Tue, 03 May 2005 15:08 Go to previous messageGo to next message
Bill, I can see what you are doing - will try it.
Yes when I think about it its only a bit? of wire and time to experiment to find a suitable taper. I might even start off with an almost balanced set of 4/5/4/4, so I can hear how the tapering actual effects the sound.
Thanks for the help - Phil
Second thoughts? [message #22612 is a reply to message #22606] Wed, 04 May 2005 06:11 Go to previous messageGo to next message
Bill– I often drawing thing up to clarify my perception of them and seem to have got “lost” with your power tapering suggestion.
Check out my drawing at: -
http://www.greenie512.net/greenie512/html/Power_Tapering.html
Jim Griffin suggests feeding more power to the central units and less to the outer drivers (left speaker on drawing). Wouldn’t your suggestion (right speaker) simply put more power to the top (or bottom – if I got the groups wrong way around?).
Sorry for hassling you when I had said I understood your suggestion earlier – I thought you were adding more to the central group when I first saw your reply.
Re: K1840 for consultation [message #22615 is a reply to message #22609] Wed, 04 May 2005 08:19 Go to previous messageGo to next message
Your right about my power tapering scheme it does provide more power to the top drivers, it kind of makes the array act like a J array, like you see at large concerts when they use many boxes of line array elements that come down and start angleing down. But like Jim said you can also do it with less power going to the center drivers and more to the outer drivers. This works to, because I heard Fred Thompsons Fred arrays this past weekend and this is how he did his power tapering. His power tapering scheme is 2/3/3/2 in series then all paralleled and they sounded good. Like I said build and test.
Re: K1840 for consultation [message #22616 is a reply to message #22615] Wed, 04 May 2005 08:52 Go to previous messageGo to previous message
Bill,
I really thinking that power tapering needs to be symmetrical with less power going to the outer drivers. Now as I have said power tapering needs to be an adjustment which balances the power injected into the room at the low end of the frequency band. So take care to work the power/room balance equation.
Jim
Previous Topic: questions on Coral drivers
Next Topic: Acrylic transfer tape?
Current Time: Tue Nov 03 08:03:12 CST 2026
