Home » Audio » Speaker » I need help in the creation of a midbass horn...
I need help in the creation of a midbass horn... [message #22596] Tue, 26 April 2005 00:41 Go to next message
Matthew is currently offline  Matthew
Hi,
I need a little help figuring out how to make a midbass (50-300 hz or so) midbass/bass horn for my newest line array project
I was going to use 8 10" midbasses in just a normal line... but I believe better results (and cheaper) can be had with a bass horn...
I would like to try a 2 15" or 2 12" (preferably the former) per tower midbass horn... I'm unsure about the length and the area "inceasing rate" of a horn like this
I would like it to look like this diagram... but I'm unsure if this would work...
two major questions... will this setup be louder than 8 10's ported??
and is seperating these two horns and having one side perfectly horizontal, will it work like I drew?
Re: I need help in the creation of a midbass horn... [message #22597 is a reply to message #22596] Tue, 26 April 2005 03:47 Go to previous messageGo to next message
Model your horn in Hornresp and fine tune it to provide the response you want. You'll need to enter driver parameters, horn length and cross-section area at various points along the path. You also need to input the radiating space you'll use it in, i.e. free space (4π), on the ground (2π) against a wall (π) or in corners (π/2).
Re: I need help in the creation of a midbass horn... [message #22598 is a reply to message #22596] Wed, 27 April 2005 07:29 Go to previous message
Check out Bill's forum.
Previous Topic: Checking with meter
Next Topic: Bastanis Prometheus vs PHY - anyone heard them?
Current Time: Thu Nov 05 23:16:07 CST 2026
