Home » Audio » Speaker » Line Arrays in Rooms w/ Sloped Ceilings
Line Arrays in Rooms w/ Sloped Ceilings [message #22507] Sun, 27 February 2005 00:11 Go to next message
Peter_S is currently offline  Peter_S
Maybe Jim Griffin, or someone else, can answer this question. I have a room with a ceiling sloping from 8' at the driven end to 14' at the other end. I know the bass response of a line array depends on reflection from ceiling and floor - and I am concerned that I will lose sufficient contribution from the ceiling side. Is this likely to be a problem? Thanks.
Re: Line Arrays in Rooms w/ Sloped Ceilings [message #22508 is a reply to message #22507] Sun, 27 February 2005 07:33 Go to previous message
Peter,
I don't think you will have a problem with your situation. With the speakers located in the area of 8' high ceiling, bass will reflect from the ceiling so it would contribute in the room just as would the floor reflections. If you placed the speakers at the other end of the room, you might experience less reflection in the bass region.
Furthermore, I would not worry too much about bass below about 200 Hz or so as it will trend toward omnidirectional in a normal sized room because of sidewall reflections. Your line arrays will continue to sound nice in this area as you'll have some directional clues versus bass from a single woofer/subwoofer. Yet with the lines you'll have good dispersion via these 'stereo' bass sources that should reduce room mode effects.
Jim
Previous Topic: Thoughts on focused arrays and the phase problem
Next Topic: measurements II
Current Time: Thu Nov 12 02:51:28 CST 2026
