Thoughts on focused arrays and the phase problem [message #22485] |
Mon, 14 February 2005 23:25  |
Dave Peterschmidt
Messages: 13 Registered: May 2009
Chancellor |
I've been kicking around the idea of designing a large line array speaker which would be essentially a floor to ceiling array. I've been doing some research along these lines, and recent ran across Jim Griffin's white paper. Excellent document! I'd like to thank Jim for his hard work that benefits so many here. Ok, to the business at hand. Since my desire is to build a tall array, it will need a way of dealing with the phase differences between the ends of the array and the middle, as outlined in the white paper. My current thinking is that some kind of focused array would be the best solution to this. However, what I had in mind differs a little from a normal concave curved front baffle. I have in mind what I call a "stepped" baffle. Basically all drivers would be oriented perpendicular to the floor as in a normal flat baffle, however, in a stepped baffle, each driver would be stepped forward a small amount as you move toward the ends of the array. This might be better than a typical focused array since the drivers at the ends of the array won't be facing the focus point directly, maintaining the cylindrical sound front better. At least that's my speculation. To understand my thinking on the reason the stepped baffle would be better than a flat baffle with power tapering, let's consider a flat baffle. This baffle can be thought of as being focused on infinity. Let's assume we have a listener whose head is positioned level with the middle of the array. The closer the listener gets to the speaker, the more pronounced the phase difference between the middle driver and the end drivers becomes. For example, if the listener is one foot from the middle driver, he would be about four feet away from the top and bottom drivers of an 8 foot tall array. A large difference. As he moves away, the distance discrepancy goes to zero as we move toward infinity. So, in short, what we have effectively is an array that would sound more phase-coherent the farther away we get, and wouldn't be optimal phase-wise until we reach infinity. This doesn't seem to be the best approach to use in practice. Let's say we step the drivers outward from the middle to the ends. Each driver sits, say, 1/4 inch forward of the one just below it (or above if we're looking at the bottom half of the array). (Note that I just picked that quarter-inch number out of the air for discussion purposes). If our array consists of 21 drivers, the top and bottom drivers would sit 2.5 inches forward of the middle driver. Now as our listener moves away from the speaker, there will be a spot somewhere before we reach infinity where the phase is close to perfect, as well as a band of area around that perfect spot where the phase is very close to perfect. Since the "optimal" listening distance band is now in the room instead of at infinity, it seems to me that the sound would, on the whole, be more coherent with this approach over most of the listening area. Not a perfect solution, for sure, but an improvement over most of the normal listening area. Obviously the step distance would vary depending on design goals and such, but it seems like some step would be preferable to a flat baffle. This would also allow the use of full power vs a power-tapered array with something less than full power. I'd love to hear anyone's thoughts on this. Is there a flaw in my thinking?
Re: Thoughts on focused arrays and the phase problem [message #22486 is a reply to message #22485] |
Tue, 15 February 2005 13:25   |
Jim Griffin
Messages: 232 Registered: May 2009
Master |
Dave, I'll take exception to your proposed design. A curved array is not necessary if your line array operates in the near field. Line arrays that are sometimes curved to yield good sound to a wider audience. Pro sound arrays use a J shaped curving to establish the close listeners in the near field and then fire the far field over their heads to the cheap seats in the balcony. Hence, the goal fot the J curve is to broaden the dispersion to the audience. The line array curving that you suggest is a concave shape that limits the effectiveness of a near field line array. With this approach you severely limit the sweet spot area. Such a design will localize the listener at the focal point of the line curvature for proper sound. No where else in the room will the sound be correctly focused or balanced. My solution is to design the line array or source with a flat baffle but place the listener in the near field of the sound. My white paper describes the criteria for near field operation of a line array. In the near field the sound radiates outward from the source parallel to the planes of the ceiling and floor. Thus, little sound energy impringes off of the ceiling or the floor. Effectively, the listener will hear only the sound localized in the horizonal plane wherein he is listening. You can do deep knee bends or stand on your tip-toes and you'll hear the same sound--the vertical coherent wavefront extends from the bottom of the array to the top of its active radiating area. Hence, once you have established a near field situation for the listening area, then you have no need to worry about the various distances from the drivers in the array to the listener. Take a look at Figure 2 in my white paper and you'll understand that the coherent sound front travels for a near field array. The sound doesn't overlap so you need not worry about different sound paths from the top and bottom of the array. Finally, you need to understand that our ears accurately locate sound direction in the horizontal plane because the shadowing of the head helps to discern direction. In the vertical plane sound localization is less accurate because our ears are in the same plane. The Haas effect also comes to contribute to minimize smearing. Bottom line is that curving the front baffle isn't needed for near field listening. The sound will be correctly balanced for sound staging and imaging throughout the listening room wherein the near field exists. You can listen close to the sources or farther away and still hear great sound. A slight power taper may help balance the in-room power response from the ends of the array. Jim
Re: Thoughts on focused arrays and the phase problem [message #22487 is a reply to message #22486] |
Tue, 15 February 2005 14:26   |
Dave Peterschmidt
Chancellor |
Jim, Thanks for responding, and again, many thanks for your excellent white paper. What you're saying makes sense to me, especially the vertical plane sound localization problems the human ear has. I do think a stepped baffle would be an interesting aspect of arrays to play around with, though. I find myself disagreeing with you a bit on the aspect of "focusing" the sound as tightly as you describe, at least with my "stepped" baffle idea as opposed to a true concave baffle. I can understand how a true concave baffle would orient the outer drivers inward toward the middle of the array and result in a tightly focused sweet spot. But I'm having trouble seeing how that effect would be created by my "stepped" baffle concept where the drivers are still oriented vertically on the baffle. Instead of a sweet-spot focusing effect, what I'm thinking you'd get would be a normal cylindrical wavefront as with a flat baffle, but with a slight reduction in the amount of smearing over entire nearfield listening area due to slightly improved phase coherency among all the drivers. Of course, in practice it may be that this effect isn't even noticable. Or I might be completely out in left field and not even close to reality. I'm just thinking out loud here...
Re: Thoughts on focused arrays and the phase problem [message #22488 is a reply to message #22487] |
Tue, 15 February 2005 14:46   |
Jim Griffin
Master |
Dave, You can do whatever you wish on this subject but I think that a stepped baffle isn't necessary. My reply was more directed toward a focused baffle than what you are suggesting. But I'm pointing out that it isn't necessary to step the baffle and in fact might lead to lower sound quality as you distrub the wavefront. I'm not buying the sound smearing issue that you raised as I believe that you don't have it in the vertical axis near field as I wrote in my earlier reply. Jim
Re: Thoughts on focused arrays and the phase problem [message #22489 is a reply to message #22488] |
Tue, 15 February 2005 15:01   |
Dave Peterschmidt
Chancellor |
Jim, Disturbing the wavefront was my concern as well. Without an array wavefront simulator of some kind it's hard to imagine all the wave interactions in my head. I plan to get some drivers in the near future and play with some cabinet mockups and we'll see what happens. I'm sure you're right, but I have this curiosity inside me to try out a stepped baffle and see what it sounds like. Maybe I'll get ambitious enough to do that someday.  By the way, do you have any thoughts on how the new CSS WR125ST would work in an array? I'd like to build using high-quality components to get a very high performing speaker, and have my eye on the 16-ohm version of this driver, to be paired up with an array of either BG Neo3 or Fountek JP-2 tweeters. The link for the CSS driver is: http://www.diycable.com/main/product_info.php?products_id=533 Thanks, Dave
Re: Thoughts on focused arrays and the phase problem [message #22490 is a reply to message #22489] |
Tue, 15 February 2005 15:45   |
Jim Griffin
Master |
Dave, I like the looks of the CSS WR125S and ST drivers. The initial reports from others are favorable. Al Wooley and CSS have demo'ed some line array models (with the WR125 drivers) and I suspect that they will be sold as kits in the near future. Most initial reports on sound quality that I have read on these designs have been mixed though but I would guess improvements are underway. The Fountek NeoCd2.0 ribbon (replaces the JP-2 version) would work great in a line array. I'm not a Neo 3 nor Neo 8 fan. Jim
Re: Thoughts on focused arrays and the phase problem [message #22492 is a reply to message #22491] |
Tue, 15 February 2005 20:04   |
Jim Griffin
Master |
Dave, No issue with single driver, MT, etc. on the WR125 designs--all glowing reports. The line array designs with the WR125's were early models just after availability of the drivers and thus had not apparently reached enough design maturity, I suspect. Again, I'm reporting what I read on the web and not personal listening experiences. On the Fountek 2.0 version it offers inherent length and minimzes the gaps which would result if you used Neo 3's in a line. Jim
Re: Thoughts on focused arrays and the phase problem [message #22493 is a reply to message #22487] |
Wed, 16 February 2005 00:39   |
jdybnis
Messages: 8 Registered: May 2009
Esquire |
Here are a couple of thoughts... In the frequency range where drivers operate in a nearfield line array, they are omnidirectional. So the angle of the driver will not make a difference. However the driver will interact with the baffle edges, the steps will make a difference there. On a large flat baffle a driver's wavefront is a coherent semi-shphere. When the wavefront encounters an edge of the baffle it defracts causing interference. This should be taken into account when designing any speaker. On a stepped baffle it will be more significant than a simple box. There will be interference above and below each driver, not only from the adjacent edges but also from the edges further away from each driver.
