| 9 fostex f200a in line array [message #22459] |
Thu, 03 February 2005 07:46  |
kloss
Messages: 36 Registered: May 2009
Baron |
Hi all was thinking about trying this out.A singal f200a gives me 30hz-21khz.I was thinking of 9 perside.This should give me a full range responce from just the 9 perside.I has also thinking of adding a t900a super tweeter crossed over very hi.Would 1 tweeter work like this or will I need to array them.
| Re: 9 fostex f200a in line array [message #22461 is a reply to message #22459] |
Thu, 03 February 2005 15:40   |
Jim Griffin
Messages: 232 Registered: May 2009
Master |
Kloss, While those Fostex drivers are very nice full range devices when used as point sources, they have limitations when you start to array them. My line array white paper (see link) details some of the design limitations. When you bring two perfect drivers together so that at a frequency wherein they are less than a wavelength (WL) center to center (ctc) apart, then their overall directivity will increase. But beyond one WL ctc, you will start to have declining directivity and eventually at a spacing of 2WL you'll have cancellation. Bottom line is that a line array composed of full range drivers will not function up to 20,000 Hz unless they have ctc spacing of less than (theoretically) 0.68" which means less than 0.68" diameter drivers spaced with their flanges touching. You can almost get by if you use less than 1.36" drivers on the same centers as the ears have less sensitivity in the 10-20 kHz octave. I have seen and heard a line array composed of 2.125" drivers spaced 2.125" ctc and it took a lot of equalization to get the upper octave to sound right. What I suggest is that you think of a two-way design that adheres to a crossover based upon the ctc critieria that is outlined in my white paper. That works. Jim
| Re: 9 fostex f200a in line array [message #22469 is a reply to message #22468] |
Fri, 04 February 2005 08:59   |
Jim Griffin
Master |
I'll use a situation wherein you have 8 inches diameter drivers mounted in a line so that their frames touch. (You can get a little closer with the F200a because of its flange configuration but not too much.) Thus, you'll have about an 8 inches center to center spacing betwen drivers. You reach one wavelength at 1695 Hz with this c-t-c spacing. I wouldn't recommend that you go much above that frequency although the really bad things don't happen until 3390 Hz. But you would need to have an agressive crossover slope to go much above 1695 Hz. One tweeter would work but recognize that you would have your woofers in a line configuration and the tweeter as a point source. Nine of the 8inch woofers would create a near field over much of your listening room while the single tweet would be a point source. Sound fall off would be 3 dB per doubly of the distance from the source for the woofers while the point source would fall off at a 6 dB rate. If your listening distance were fixed, you could balance the sound but if you wish to have well balanced sound throughout the room you would need a line of tweeters (long enough to create a near field). Jim
| JBL 2115 [message #22470 is a reply to message #22468] |
Fri, 04 February 2005 09:02   |
Messages: 19105 Registered: January 2001
Great link! There is some very cool stuff there! That Fostex F200 always reminds me of the JBL 2115, which was an absolutely awesome 8" driver of the 1980's. The driver was flat over an amazing range, from 30Hz to 10kHz. It had a shorting ring, so distortion was very low. The shape of the basket, the brushed finish and shape of its face, the cone, surround and voice coil cover were the same. So I'm thinkin' the Fostex F200 must share a lot with the JBL 2115 more than just looks, and that leads me to believe it must be an excellent part. Have you ever seen or heard a JBL 2115?
| Re: JBL 2115 [message #22473 is a reply to message #22471] |
Fri, 04 February 2005 10:03   |
Thanks for your reply. I'll have to evaluate that F200 sometime. I've been meaning to do that ever since I noticed the similarity between the F200 and the JBL 2115. I was disappointed when JBL discontinued the 2115, but it didn't really fit in their 20xx/21xx/22xx/24xx product lineup, so I think that's why they moved on towards midrange products of that size. The 2115 is truly a full range driver. I appreciate your enthusiasm about the F200, but don't discount the 2115. JBL's engineers really do their homework and that 2115 was the best driver of its type I've ever heard. I'll check the F200 and see how close they've come. Thanks for the heads-up; I think I'll really enjoy the F200.
| Re: JBL 2115 [message #22475 is a reply to message #22474] |
Fri, 04 February 2005 12:17   |
Sounds cool, I'll bet your speakers are awesome. The 2115 is old, that's for sure. In fact, you can't even get recone kits for it anymore, so it has become really rare. The F200 is definitely more feasable. I know that Fostex makes good products, 'cause I've heard some very nice sounding Fostex speakers. The single driver speakers I've liked the most in the last couple of years have used Fostex drivers. Who is doing their engineering over there? Do you know who any of the people are doing R&D at Fostex? I'm thinking there must be some clever folks there because they have made some very fine speakers. That's one thing about JBL, their R&D team is comprised of some very good engineering talent. I'd say they've kept themselves in pretty good shape as far as advances in technolgies and materials are concerned. The list of engineers and people involved there reads like a "Who's Who in the Audio Industry."
