Home » Audio » Speaker » 16 ohm line array
16 ohm line array [message #22414] Fri, 24 December 2004 00:11 Go to next message
Sidewinder is currently offline  Sidewinder
Hello,
I've bought 40 of the cheap drivers and I want to build a 16 ohm version of the TLAH. I need some help. What are some possible ways I could wire these drivers? Another question concerns the enclousure dimensions. The top of the baffle shows 17"s tapering down to 12"s with overall length 38"s If I were to use 16-20 drivers instead of 8 as in the original version, how would the dimensions change for this baffle and the other sides? Any help would be appreciated. Thanks
Regards,
David
Re: 16 ohm line array [message #22415 is a reply to message #22414] Fri, 24 December 2004 16:22 Go to previous messageGo to next message
I'd answer you here but that would leave the rest of the guys at the Bill Fitzmaurice forum out of the loop. Suggest you ask over there.
Thanks Bill, will do. nt [message #22416 is a reply to message #22415] Fri, 24 December 2004 23:29 Go to previous message
Go to:
Previous Topic: Maggie 2.7
Next Topic: Improve Bass
Current Time: Mon Oct 19 10:49:33 CDT 2026
