Home » Audio » Speaker » 3-way arrays
Re: 3-way arrays [message #22366 is a reply to message #22364] Thu, 11 November 2004 11:11 Go to previous message
Allan is currently offline  Allan
Thanks for the input Jim.
"Another thought is to use a separate box for the 10's but hard for me to say without more details."
That's an idea I've been entertaining as well.
" I assume that you will crossover to the 4" mids in the 100-300 Hz range..."
Exactly. I have high sensitivity (~97db) subs/bass boxes already, but they really start losing their charm above 100Hz. Everytime I want to think about a new array using say, 3 inch drivers, or any other type of speaker with a mid range that needs crossing at 250-300hz, I'm stuck with no way to bridge the gap between them and the subs. If I build the bass array separately, I could use it for other projects.
"You did not say whether you plan sealed/vented/open enclsoures so it is hard to guessimate how the bass will react. My personal preference is for sealed enclosures for their better transient response."
Ditto here too. I want to use sealed all the way thru.
Thanks again.
Allan
Previous Topic: need suggestion for EV problem
Next Topic: Doping
Current Time: Fri Oct 16 17:18:19 CDT 2026
